    Expansion stepper Breakout + TB6600
    tb6600 expansion duet wiring
    • Corvonero
      Corvonero last edited by
      I connected the Expansion stepper Breakout to my Duet Wifi, I wired my Tb6600 Stepper, i remapped the Z Axis but nothing happened, my Nema doesn't move.
      I need to connect 4 Tb660 to connect my 4 Nema to move the Z axis of my Big Printer.
      TB6600--->Expansion Board
      ENA- --> E-
      ENA+ --> E+
      DIR- --> D-
      DIR+ --> D+
      PUL- --> S-
      PUL+ --> S+
      I connected VCC and GND to 12v on my PSU
        Those connections look correct to me. How did you remap the Z axis? Did you get any error messages when you tried to jog the Z axis?
        • Corvonero
          i used M584 Y2 Z5:6:7:8
          When i try to move Z axis stepper motor doesn't move and i didn't get any message
            Did you use the T parameter in the M569 commands for the external drivers, to increase the step pulse width? Most external drivers need this.
            • Corvonero
              I've Tried with M569 P5 R1 T3 but nothing change
              • Corvonero
                I've mesured with the multimeter Dir - e dir+ and it says +3.3V when i go "up" and -3.3V when i go "down". but my stepper motor doesn't move
                • Corvonero
                  M569 P5 R1 T2.5:2.5:5
                  now i've used this command and all worked fine
                  Ty for all the Help!
