    Pause and resume within a macro
    Firmware wishlist
    1.4k
    • Ethelredundefined
      Ethelred
      According to the Duet3d G-code wiki
      " M25 is intended for use from a different source of GCodes (like the web interface console, PanelDue or Macro) ". Doesn't work for me and a console message says "ERROR M25 Cannot pause print because no file is being printed".
      I'd really like to be able to run a macro and
      Pause ( with message )
      Resume from a WC or PanelDue resume button in the same manner as occurs when running a gcode file.
      Any way to do attempt a work-around I've tried creating a code file with cold extrude option but have run into difficulty.
      What am I doing wrong ?
        M25 is for pausing a file being printed from SD card. Use M291 to pause with a message from within a macro..
        • Ethelredundefined
          Ethelred
          Thanks, works great. I'd have wished that in addition that the Message/Acknowledge displayed on PanelDue.
            dc42 administrators @Ethelred
            @balrags said in Pause and resume within a macro:
            It is, if you use version 1.20 or 1.21 PanelDue firmware.
            • Ethelredundefined
              Ethelred
              Got it, thanks but interestingly, for some reason, the "no-logo" version failed (command line input) but the other loaded correctly. I can live with the advert.
              • T3P3Tonyundefined
                T3P3Tony administrators @Ethelred
                @balrags The "no-logo" version is there to allow you to add your own logo:
                The integrated and -v3- binaries display a splash screen at startup. If you want to use a custom splash screen instead, choose the -nologo variant of the binary file and see https://github.com/dc42/PanelDueFirmware/blob/master/Readme.md for further instructions.
                www.duet3d.com
                  The nologo versions should work as-is too.
