Setting up mixing hot ends such as the Diamond
In conjunction with Tony, I've created a guest blog post on Think3dPrint3d, which aims to cover all the aspects of setting up and using a mixing hot end such the Diamond, with Duet electronics. Here is link http://blog.think3dprint3d.com/2016/12/using-diamond-hotend-with-duetwifi.html.
Tony plans to adapt it to a Wiki page as well, when he gets time.
Hope others will find the info useful.
Nice write up Ian might have to get my self a cyclops heatblock and convert my Chimera?
Doug.
Hi Doug,
Having a single nozzle makes life sooooo much easier. My first excursion into colour printing was with 3 hot ends on a RRP Mendel and compared to that, the Diamond is a great improvement. Does the Cyclops use standard (changeable) nozzles ? - it looks like it does. That would be a good feature to have. I haven't tried some of the more exotic filaments with the Diamond because it's a brass nozzle and can't be changed if it wears. Shame the Cyclops only has 2 inputs though, and I'm guessing that, like the Diamond, it won't actively mix.
yes it does use std E3D V6 nozzles and is a lot lighter/more compact than a diamond as for mixing I'm not sure the drawings of the heater block like like it will do a bit of mixing but not to certain not exactly the cheapest thing tho at £40 + the dreaded just for the blocm never mind anything else but it does look like it will be a damn sight easier to clean out if needed?
will keep you informed if/when I do it
Doug
The cyclops is like the diamond in the sense that while it's multiple inputs, a single output, it does not mix the filaments actively so you get different Colo in different sides of the print
The Cyclops is not compatible with standard V6 nozzles, that's one of the reason I am holding off buying it.
I am pretty interested in getting a Diamond hotbed for my Kissel though.
Jackel you are right I hadn't spotted that it puts a different perspective on it?
Doug
