    Help with setting up motors.
    1740
    • Saltypetz
      Saltypetz last edited by Saltypetz
      I am wonder If maybe someone could be a little helpful to me set up the motors. I am asking for help. I don't want to waste anymore time I need this printer to print. I don't understand how to put the information in the reprap software.
      Here is the extruder I have.
      https://micron-eme.com/collections/all-metal-extruders/products/high-temperature-cobra-1-75mm-extruder-up-to-400-degrees-c
      Here is the data sheet.
      https://cdn.shopify.com/s/files/1/0388/6813/files/28PA13.7G-28BYG32-067-4A-Arik.pdf?10564183021920850872
      Here are the motors I am running.
      Kysan 1124090 Nema 17 Stepper Motor
      https://cdn.shopify.com/s/files/1/1223/5992/files/Nema17StepperMotor.pdf?6848101445132525963
      • Dougal1957
        Dougal1957 last edited by
        So what is the question exactly?
        it would help to have a little more info from you and I don't believe that you have had no help from the forum in over a month it is the most helpful knowledgable group of guys and gals I know.
        • jmjcoke
          jmjcoke last edited by
          You seem to dislike building a 3D printer.
          1. Sell all the stuff you bought.
          2. Buy a printer you will enjoy( Raise3D N2 or new Pro2)
          3. Don't ever try to build another printer.
          • Saltypetz
            I was told to use this information that I have been trying for a month witch for some reason doesn't work with my board.
            M307 H3 A-1 C-1 D-1
            M558 P9 H5 F100 T2000
            G31 X0 Y0 Z0 P25
            I have to use this setting that I just tried yesterday.
            M307 H7 A-1 C-1 D-1
            M558 P5 H5 F100 T2000
            G31 X0 Y0 Z0 P25
            jmjcoke deckingman 2 Replies Last reply Reply Quote 0
            • jmjcoke
              jmjcoke @Saltypetz last edited by
              @saltypetz I have been a CNC field service engineer for 20 plus years. You are wrong. The information provided is more than adequate, you just do not want to spend the time needed to successfully commission a new machine.
              You did not buy your own control and a frame and build your own CNC. A portion of the 100k you spent on a finished machine is the fact that someone else designed and programmed the machine. Your the designer when you buy a control and build a machine.
              • Saltypetz
                All I did was asked for was help and I got the wrong answer.
                Dougal1957 1 Reply Last reply Reply Quote 0
                • Dougal1957
                  Dougal1957 @Saltypetz last edited by
                  @saltypetz said in Help with setting up motors.:
                  All I did was asked for was help and I got the wrong answer. So it took me a month of lost time because someone gave me the wrong information and I had to figure it out. I have also been working with CNC machines 20+ years. I have two other printers using Rambo Boards and you can call they if you have problem.
                  Actually I have searched your previous questions and you got good advice in them but this question here has not been asked as far as I can tell!
                  The M307 and M558 and even the G31 lines have nothing to do with the motor settings that you appear to be asking this time please make it clear what problem you are having in understanding the issue and we may be able to help you but as of now i'm afraid my crystal ball just isn't working?
                  • Saltypetz
                    Now Everything works great I just don't understand in the reprap software how to setup the motors.
                    They are going way to slow. It took me a month to figure out my first problem I just can't keep wasting time.
                    I don't understand how to set up the motors. That's why I posted all the links to make sure all the information was there. I have been reading on it but I can't really find anything.
                    Thank you for your help.
                    • Dougal1957
                      OK so now we are getting somewhere can you post your full Config.g file please and confirm that the motors are slow all the time or only in certain instances like homing or bed probeing
                      • Saltypetz
                        ; generated by RepRapFirmware Configuration Tool on Sat Mar 03 2018 14:29:05 GMT-0500 (Eastern Standard Time)
                        M550 P"Black Widow" ; Set machine name
                        M552 S1 ; Enable network
                        M587 S"NETWORKNAMEHERE" P"NETWORKPASSWORDHERE" ; Configure access point. You can delete this line once connected
                        M586 P0 S1 ; Enable HTTP
                        M586 P1 S0 ; Disable FTP
                        M586 P2 S0 ; Disable Telnet
                        M569 P0 S1 ; Drive 0 goes forwards X
                        M569 P1 S0 ; Drive 1 goes backwards Y
                        M569 P2 S1 ; Drive 2 goes backwards Z
                        M569 P3 S1 ; Drive 3 goes forwards E
                        M92 X157.64 Y157.64 Z5120 E301.54 ; Set steps per mm
                        M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
                        M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
                        M906 X1200 Y1200 Z1200 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X335 Y260 Z250 S0 ; Set axis maxima
                        M574 X1 Y1 S1 ; Set active low endstops
                        M574 Z1 S1 ; Set endstops controlled by probe
                        M558 P5 H5 F120 T6000
                        M557 X0:335 Y45:260 S20 ; Define mesh grid
                        G31 X0 Y0 Z0.221 P25
                        BLTouch
                        M307 H7 A-1 C-1 D-1
                        M301 H0 S1.00 P32.6 I1.360 D79.4 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                        M143 H0 S80 ; Set temperature limit for heater 0 to 80C
                        M305 P1 X150 T"K" ; Set thermistor + ADC parameters for heater 1
                        M143 H1 S240 ; Set temperature limit for heater 1 to 220C
                        M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M563 P0 D0 H1 F2 ; Define tool 0
                        • deckingman
                          deckingman @Saltypetz last edited by
                          This post is deleted!
                          • Saltypetz
                            Is there something I can do to set the motors up in reprap or do you do it manually. If I understood how to read the data sheet to put it into reprap I would try or maybe it is more then just that.
                            • AndreS
                              AndreS last edited by
                              I think Y20 is slowing everything down.
                              • deckingman
                                Well you've done all there is to do. That is set the motor current - (generally 85% of maximum rated current is good value), and set the direction (which should be obvious). Other than that, everything else such as steps per mm, speeds and accelerations, depend on your machine configuration.
                                • Dougal1957
                                  Dougal1957 last edited by Dougal1957
                                  Ok these 3 lines are what basically controls the motors and for yours it think you should increase the values in the M203 to something like
                                  M203 X18000 Y18000 Z300
                                  you accelerations look way of as well but I don't know the TEVO but the Y value of the M201 looks very strange to me and I would have expected it to be similar to your X value and I would suggest that your currents for your motors are a bit high i would try with
                                  M906 X1000 Y1000 Z1000 E450 I30
                                  Also your steps/mm seem a bit strange what toothed pulleys and belt does it use?
                                  HTH at least a little bit (it looks to me like you have just taken the Steps/mm from your old controller which was probably set to 32 micro step mode so I think you need to halve the values in your M92 line although having looked at the extruder manual I think it needs to be increased for E0) According to the extruder data I think 1168 is the correct value for E0
                                  • Dougal1957
                                    each motor is rated at 1.5 amps except the extruder which is 0.67 hence my figures
                                    all are 1.8 deg motors AFAICT
                                    • Saltypetz
                                      Everyone thank you for the help. Hopefully I can get it going today. I checked the board and it is a v1.03 I don't understand why this doesn't work but we got it working now.
                                      M307 H3 A-1 C-1 D-1
                                      G31 X0 Y0 Z0 P25
                                      • Dougal1957
                                        M307 H3 A-1 C-1 D-1
                                        G31 X0 Y0 Z0 P25
                                        Those lines have no baring on the issue you have been complaining about (Slow motor speeds) so what have you done to fix it can you post your new revised Config.G for others to find and see?
                                        • Saltypetz
                                          It has two lead screws with a belt and one motor.
                                            As @Dougal1957 said, those are unusual steps/mm values for X and Y - but not impossible.
                                            Those values are OK, however I suggest you reduce the X and Y values to 600 until you know that higher is OK for your machine.
                                            Those are conservative values and could probably be increased, but I suggest you leave them alone for now.
                                            The Y value is too low, try 500. The Z value may be too high, I suggest 100 for now, maybe increase later when everything is working.
                                            The extruder motor has a rated current of 0.67A, so use E400 or E500 in that line. Otherwise OK. If the XYZ motors get too warm, reduce the currents from 1200 to 1100 or 1000.
                                            • Saltypetz
                                              As soon as I try to update the motor settings it doesn't start in the middle hot it goes to the far right corner. Also when I tell it to mesh it starts at about 100mm in from the front of the bed. May I did something wrong but before updating the speed it worked perfect. Is there somewhere I can read so I understand about the motors setup.
                                              Here is the Config file.
                                              M92 X157.64 Y157.64 Z5120 E301.54 ; Set steps per mm for 16x microstepping
                                              M566 X600 Y600 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                                              M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                                              M106 P1 S1 I0 F500 H1 T100 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                              M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                              M307 H7 A-1 C-1 D-1 ;
                                              M558 P5 X0 Y0 Z1 H9 F200 T6000
                                              G31 X-48.8 Y-18.2 Z0.445 P25
                                              M501
                                              T0 ; Select first tool
                                              • Saltypetz
                                                I have been messing around with the motor setting. When I change this line the beg starts about 100mm in from the front and about 30mm from the left. M92 X157.64 Y157.64 Z5120 E301.54 when meshing the bed. Also if I do Z home it goes to the far right corner not the middle of the bed.
                                                Just from messing around with it this works perfect so far.
                                                M92 X90.64 Y90.64 Z5120 E456 ; Set steps per mm
                                                • T3P3Tony
                                                  T3P3Tony administrators @Saltypetz last edited by
                                                  @saltypetz generally steps/mm for motion axis should be calculated, not determined by experiment.
                                                  Prusa has a good calculator:
                                                  for belt
                                                  https://www.prusaprinters.org/calculator/#stepspermmbelt
                                                  Or leadscrews
                                                  https://www.prusaprinters.org/calculator/#stepspermmlead
                                                  • Saltypetz
                                                    Is there more information that I can read so I have a better understanding what all the numbers are for.
                                                    I went on the calculator but I want to have better understanding of all the settings. I want to understand what they all do. If there is a link to something I can read can you please post the link.
                                                    Thank you, everyone for the help.
                                                    • Saltypetz
                                                      Could the belt be the problem making it go across the bed. I am looking for information on it now.
                                                      Here is the link to the belt. https://tevo3dprinterstore.com/products/10meter-gt2-6mm-open-timing-belt
