Scalloping Issue
  • Quick Machine Specs:
    CR-10 Custom Clone
    Dual extruders with steppers on x carriage
    Standard 16 microstep with interpolation
    Running V1.19 Firmware
    I have a very peculiar issue with my 3d printer I just finished building, (Pics, vids, and CAD files coming soon in another topic) where on some STL files I am getting a scalloping effect where the lines between wall points are concave and very noticeable.
    Here are some pics regarding what I am talking about. For reference the Bunny is downloaded from Thinigiverse and I would assume is a somewhat low poly count figure, while the Shark is my own creation and is of the highest poly quality Fusion 360 allows.
    MicroSD card included for scale.
    The shark which shows no scalloping
    The shark which shows no scalloping and nice smooth curves.
    The bunny showing severe scalloping between wall points
    Also note in the next picture that the scalloping scale changes in proportion to the curve radius.
    Scalloping gets tighter around mouth/nose where curve radius tightens
    Scalloping gets tighter around mouth/nose where curve radius tightens.
    Based on the fact that it was able to produce smooth curves on the shark I am very confident mechanical problems are not part of this issue. I am inclined to think it is something to do with the interpolation on the steppers but idk.
    The bunny STL is available at https://www.thingiverse.com/thing:2832177
    The shark STL is available at https://www.thingiverse.com/thing:2804703
    Both were printed with the exact same Cura settings, and no firmware setting changes either.
    My next troubleshooting question is really should I be looking at the Duet or Cura for this issue because when I preview the gcode files I don't see the scalloping that results. (Making me think it's the Duet)
    Let me know if you would like me to post more info such as config.g or Cura settings.
    Thank you in advance. Excellent product the Duet is, I am just so happy with my purchase.
  • Now that I am thinking about it I know you'll want to know my speed settings as I am starting to think I may have my instantaneous accel (jerk) too low. Here is my config with password redacted obviously.
    ; Configuration file for Duet Ethernet (firmware version 1.17 to 1.19)
    ; generated by RepRapFirmware Configuration Tool on Sat Apr 21 2018 08:39:01 GMT-0400 (Eastern Daylight Time)
    M550 PJP-440 ; Set machine name
    M551 Phahahahnoway ; Set password
    M540 PIN:VA:LI:DE ; Set MAC address
    M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
    M586 P0 S1 ; Enable HTTP
    M586 P1 S1 ; Enable FTP
    M586 P2 S1 ; Enable Telnet
    M569 P4 S1 ; Drive 4 goes backwards
    M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
    M92 X79.635 Y80.2 Z395 E164.4:164.4 ; Set steps per mm
    M566 X54 Y54 Z100 E180:180 ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000 Y6000 Z400 E4800:4800 ; Set maximum speeds (mm/min)
    M201 X300 Y300 Z1900 E1080:1080 ; Set accelerations (mm/s^2)
    M906 X1200 Y1360 Z1200 E1100:1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-63 Y-8 Z.25 S1 ; Set axis minima
    M208 X352 Y377 Z385 S0 ; Set axis maxima
    M574 X1 Y1 Z1 S0 ; Set active low endstops
    M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
    M143 H2 S280 ; Set temperature limit for heater 2 to 280C
    M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 F1:2 S"Left Extruder" ; Define tool 0
    G10 P0 X28.5 Y0 Z0 ; Set tool 0 axis offsets
    M563 P1 D1 H2 F1:2 S"Right Extruder" ; Define tool 1
    G10 P1 X59.15 Y0.46 Z0 ; Set tool 1 axis offsets
    G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
  • Moderator
    @hpiz said in Scalloping Issue:
    M566 X54 Y54
    That's very very low for jerk. Remember, it's mm/min not mm/s.
    Try a value of 500 or so.
  • @phaedrux said in Scalloping Issue:
    M566 X54 Y54
    You're right, I was thinking per second. Printing the bunny again at 540.
    I went ahead and added an order of magnitude to all the values I had for jerk.
    I'll update with the results.
    Thanks.
  • alt text
    Much better results, but I'm guessing I can go even further. Thanks for the tip.
