Strange z offset after printing.
Hi all. I am having an issue where when I finish a print the z will be offset by a seemingly random amount. Re homing the z doesn't fix it. If I home Z and go to 10mm in z then say z0 the duet will read Z 0.4 ( or some other number, it changes ). a power cycle and subsequent homing does fix it.
My printer is a Voron 1.5, coreXY with a Duet Wifi on 1.20 using S3D to slice my STL's. I can post my config.g and S3D start/ end scripts as needed. ( scripts were from another friend who also has a voron but he hasnt been available lately for me to ask.)
Any help is greatly appreciated.
Are you using Mesh Bed Compensation?
A few more details would be helpful, like what z probe type. Posting your config is always helpful.
How is the Voron by the way? If I were to build another printer I think it would be a Voron 2.0
No Mesh Bed Compensation. I am using a PL-08N inductive sensor as my Z probe. I love my Voron. It's my second printer ( but first built. First printer was an FLsun delta) and I am currently building a V2. I have been using my V1 in a coroplast box to print ABS parts for my V2. Works quite well, though not perfect.
My config:
; generated by RepRapFirmware Configuration Tool on Mon Nov 20 2017 00:03:40 GMT-0500 (Eastern Standard Time); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
; Automatic saving after power loss is not enabledM667 S1 ; Select CoreXY mode
M208 X300 Y300 Z300 S0 ; Set axis maxima; Endstops
M574 X2 Y2 S0 ; Set active low endstops;Z-Probe
M558 P5 H3 I1 F120 T9000 ; Set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y-40 Z2.0 ; Set Z probe trigger value, offset and trigger heightM557 X50:250 Y50:250 S20 ; Define mesh grid
M92 X80 Y80 Z400 E608 ; Set steps per mm
M566 X420 Y420 Z100 E72 ; Set maximum instantaneous speed changes (mm/min)
M203 X16000 Y16000 Z1000 E5400 ; Set maximum speeds (mm/min)
M201 X2250 Y2250 Z500 E3000 ; Set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Bed Heater (H0)(Keenovo 120v 600W powered through SSR)
M143 H0 S125 ; Set maximum heater temperature to 125C
M305 P0 T100000 B3950 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 0; Here I record the results of all my 'M303 H0 S120' autotunes for the bed
; Heater 0 model: gain 236.9, time constant 509.8, dead time 1.1, max PWM 1.00, calibration voltage 24.5, mode PID
; Heater 0 model: gain 230.9, time constant 494.7, dead time 1.1, max PWM 1.00, calibration voltage 24.5, mode PID
; Heater 0 model: gain 316.0, time constant 482.7, dead time 1.4, max PWM 1.00, calibration voltage 24.5, mode PID
; Heater 0 model: gain 271.9, time constant 601.0, dead time 1.2, max PWM 0.80, calibration voltage 24.5, mode PID
; Then set the M307 parameters with a rough average
M307 H0 A316.0 C482.7 D1.4 S0.6 B0 ; Set model parameters for heater 0 and use PID mode?; Hot End Heater (H1) (E3D-V6 24v 40W)
M143 H1 S280 ; Set maximum heater temperature to 245C
M305 P1 T100000 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1; Here I record the results of all my 'M303 H1 S240' autotunes ********* FOR E3D V6 24v 40W **********
; Heater 1 model: gain 483.0, time constant 183.7, dead time 4.9, max PWM 1.00, calibration voltage 24.5, mode: PID
; Heater 1 model: gain 320.5, time constant 123.3, dead time 3.2, max PWM 1.00, calibration voltage 24.5, mode: PID
; Heater 1 model: gain 322.3, time constant 122.2, dead time 3.4, max PWM 1.00, calibration voltage 24.5, mode PID
; Then I set the M307 parameters with a rough average
M307 H1 A322.3 C122.2 D3.4 B0 ; Set model parameters for heater 1 and use PID mode
M307 H2 A-1 C-1 D-1
; Extruders; Tool/Extruder 0
M563 P0 D0 H1 ; Tool 0 uses Drive 0 and Heater 1
G10 P0 X0 Y0 Z0 ; Set Tool 0 axis offsets
G10 P0 R0 S0 ; Set Tool 0's initial active and standby temperatures to 0CT0 ; select Tool/Extruder 0 by default
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PVoron ; Set machine name
M552 S1 ; Enable network
M587 S"ASUS" P"Threatlevel302" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
@lolmodule What does your homez.g look like?
Also please post your homeall.g file, and tell us which firmware you are using.
I am running 1.20 firmware.
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool on Mon Nov 13 2017 23:47:22 GMT-0600 (Central Standard Time); Relative positioning
G91; Lift Z
G1 Z3 F9000; Course home X or Y
G1 X332 Y318 F2500 S1
; Course home X
G1 X332 S1
; Course home Y
G1 Y318 S1; Move away from the endstops
G1 X-5 Y-5 F2500; Fine home X
G1 X332 F360 S1
; Fine home Y
G1 Y318 S1
; Absolute positioning
G90; Go to middle of bed and home Z
G1 X150 Y150 F9000
G30; Uncomment the following line to lift the nozzle after probing
G1 Z10 F150
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool on Mon Nov 20 2017 00:03:40 GMT-0500 (Eastern Standard Time); Lift Z relatively to current position
G91
G1 Z5 F6000; Back to absolute positioning
G90; Go to first bed probe point and home the Z axis
G1 X150 Y150 F6000
G30; Uncomment the following lines to lift Z after probing
G91
G1 Z10 F100
G90 -
Do you see any signs of skipping steps on the Z axis? If you run it up and down does it sound smooth and consistent? Any signs of binding? Are you running the Z motors at ~85% rated current?
I'm not familiar with your probe type, so I don't know what to look for to see if it's functioning properly or not.
On power up, all settings will be read in from config.g (and or config-overide.g if you use it). So if a power cycle fixes it and homing works fine, then logic would dictate that there is something in the print gcode file that is changing a setting. It might be an idea if you post the first and last 50 or so lines of the gcode file that your are printing - especially the parts that contain your start, and more importantly your end, gcode.
I am not getting binding on Z and do not see any skipping. Im fairly certain the probe its self is functioning properly.
Start Script:
T0
M104 S0 ;cancel S3D set temp
G21 ; set units to mm
G90 ; use absolute coordinates
T0 ; select tool 0
M207 S8.5 F4000 T1800 Z0.4 ; setup firmware retractionG92 E0.0 ; reset e count
M220 S100 ; reset speed multiplier
M140 S[bed2_temperature] ; set bed temperature and do not wait
M109 S205 ; set print head temperature and wait
M190 S[bed2_temperature] ; set bed temperature and waitM140 S[bed2_temperature] ; set bed temperature and do not wait
M109 S[extruder0_temperature] ; set print head temperature and wait
Post processing for FW retraction
{REPLACE "G1 E-1.0000 F6000\n" "G10\n"} ; firmware retract
{REPLACE "G1 E1.0000 F6000\n" "G11\n"} ; firmware unretract
{REPLACE "G1 E1.0000 F1800\n" "G11\n"} ; firmware skirt unretract
Ending script
G91 ;relative positioning
G1 E-5.00 F1000 ;retract 5mm of filament
G1 Z+1.00 X+20.0 Y+20.0 F20000 ;short quick move to disengage from print
G1 Z+10.00 F20000 ;move Z-Axis 10mm away from partG90 ;absolute positioning
G1 X10 Y10 ; move gantry close to home
G91 ; relative positioningG1 E-5.00 F500 ;retract additional filament to prevent oozing
M104 S0 ;turn off hotend
M140 S0 ;turn off heatbed
M106 S0 ; shut off blower
The scripts are not made by me ( they are from a friend that also has a Voron).
@lolmodule said in Strange z offset after printing.:
What happens if you send this command manually? Does it successfully move 10mm?
@phaedrux said in Strange z offset after printing.:
Yup. That looks like a very high feed rate for the Z axis. I'd think that may well be the problem.
I can't see anything obviously wrong with your files. Two possibilities:
This issue might be related to the one that I fixed in firmware 2.0, even though that one was most evident when using mesh bed compensation. So you could try upgrading to firmware 2.0.
If the print file is somehow changing the babystepping amount or the tool Z offset, that would cause the problem. So try sending the following commands after a print and check that the results returned are correct:
G31 T5 ; should return trigger height = 2.0
M290 ; should return zero, or whatever babystepping you used
G10 P0 ; should return Z offset = 0 -
Ok. I re did my Z0 and my probe trigger height just to make sure everything was ok. Which is why my trigger height is a tad different than before. I printed a calibration cube and put in the commands you suggested @dc42 this is the results:
G10 P0
Tool 0 offsets: X0.00 Y0.00 Z0.00, active/standby temperature(s): 0.0/0.0M290
Baby stepping offset is 0.000mmG31 T5
Threshold 500, trigger height 2.19, offsets X0.0 Y-40.0Everything looks good right?
https://gyazo.com/e708fbecbdc5baf48ebf945f10f2fadf
Notice the commanded position and the readout in the top right.
I tried the suggestion by @Phaedrux and manually entered that move command ( verified Z 0, sent the G1 Z+10.00 F20000, then back to 0 and it was fine.)
I have no idea whats going on. I haven't updated to 2.0 yet but I think it might fix whatever issue I might be having but I will wait to see what you all have to say.
I really do appreciate the time you guys ( even though it may not be much time) put into helping me out.
It looks to me that you have some sort of bed compensation in use that is causing a 0.4mm adjustment. Please run M122 and see what the "Bed compensation in use" field reports.
Another possibility is that the GCode file you printed uses a M206 commands to offset the Z axis.
No bed compensation: https://gyazo.com/9193b8b3715ef0341789c3e7e04b06f3
Checked the last few files and there are no M206 commands. My start script does have an M207 that has a Z0.4 in it.
Could that be it? like I mention earlier I am not fully up on Gcode so when my friend gave me the scripts for FW retraction I just used them. Is there a reason to have a Z0.4 in the FW retraction?
The Z parameter for firmware retraction controls Z hop.
Ah ok. I dont know what the issue could be then... Everything appears to be setup right.
Might be time to give 2.0 a try.
If that doesn't work, you could try backing up all your existing config files from the /sys folder and then starting fresh with a new config bundle generated by the RepRap configurator. It would likely take some tuning and adjusting to get it working properly for your printer again, as the configurator really provides more of a starting point than a final working config. This would also give you a chance to dig into RepRap firmware and gcode a little more which is really quite powerful once you get into it.
I still suspect some binding or skipped steps occasionally, can you verify what the rated current for your z stepper is and whether you're running it at close to 85% of rated?
I thought that the 20,000 mm/min (333mm/sec) for the Z move in the end gcode was way too fast (which it is) but then it'll be limited to 1,000 because that's what is in config.g.
Like Phaedrux, I'm also inclined to think it's binding or skipping steps. You could try lower Z acceleration.
It may be that, but like I posted above. I ran that high Accel z move manually and it returned to 0 no problem. ( But that doesn't mean it isn't the cause)
@lolmodule Just a theory, but at the end of the print the motor may be hot and may not respond the same.
@phaedrux that's possible. I'm running dual leadscrew steppers for my Z so I didn't think it could be that but it's definitely not out of the realm of possibility.
I updated to 2.0. printed a calibration cube. removed the print and sent the head to X150 Y150 Z10 ( 10mm above the center of my bed) and this is the result...
https://gyazo.com/384ec6ddfaa195b510a2755408a18a8c
No more strange offset after a print!
Thanks to everyone for all the help and tips!
