    Strange z offset after printing.
    3.0k
      deckingman
      On power up, all settings will be read in from config.g (and or config-overide.g if you use it). So if a power cycle fixes it and homing works fine, then logic would dictate that there is something in the print gcode file that is changing a setting. It might be an idea if you post the first and last 50 or so lines of the gcode file that your are printing - especially the parts that contain your start, and more importantly your end, gcode.
      • lolmoduleundefined
        lolmodule
        I am not getting binding on Z and do not see any skipping. Im fairly certain the probe its self is functioning properly.
        Start Script:
        T0
        M104 S0 ;cancel S3D set temp
        G21 ; set units to mm
        G90 ; use absolute coordinates
        T0 ; select tool 0
        M207 S8.5 F4000 T1800 Z0.4 ; setup firmware retraction
        G92 E0.0 ; reset e count
        M220 S100 ; reset speed multiplier
        M140 S[bed2_temperature] ; set bed temperature and do not wait
        M109 S205 ; set print head temperature and wait
        M190 S[bed2_temperature] ; set bed temperature and wait
        M109 S[extruder0_temperature] ; set print head temperature and wait
        Post processing for FW retraction
        {REPLACE "G1 E-1.0000 F6000\n" "G10\n"} ; firmware retract
        {REPLACE "G1 E1.0000 F6000\n" "G11\n"} ; firmware unretract
        {REPLACE "G1 E1.0000 F1800\n" "G11\n"} ; firmware skirt unretract
        Ending script
        G91 ;relative positioning
        G1 E-5.00 F1000 ;retract 5mm of filament
        G1 Z+1.00 X+20.0 Y+20.0 F20000 ;short quick move to disengage from print
        G1 Z+10.00 F20000 ;move Z-Axis 10mm away from part
        G90 ;absolute positioning
        G1 X10 Y10 ; move gantry close to home
        G91 ; relative positioning
        G1 E-5.00 F500 ;retract additional filament to prevent oozing
        M104 S0 ;turn off hotend
        M140 S0 ;turn off heatbed
        M106 S0 ; shut off blower
        The scripts are not made by me ( they are from a friend that also has a Voron).
          Phaedrux Moderator @lolmodule
          @lolmodule said in Strange z offset after printing.:
          What happens if you send this command manually? Does it successfully move 10mm?
            deckingman @Phaedrux
            @phaedrux said in Strange z offset after printing.:
            Yup. That looks like a very high feed rate for the Z axis. I'd think that may well be the problem.
              I can't see anything obviously wrong with your files. Two possibilities:
              • This issue might be related to the one that I fixed in firmware 2.0, even though that one was most evident when using mesh bed compensation. So you could try upgrading to firmware 2.0.
              • If the print file is somehow changing the babystepping amount or the tool Z offset, that would cause the problem. So try sending the following commands after a print and check that the results returned are correct:
              G31 T5 ; should return trigger height = 2.0
              M290 ; should return zero, or whatever babystepping you used
              G10 P0 ; should return Z offset = 0
                lolmodule
                Ok. I re did my Z0 and my probe trigger height just to make sure everything was ok. Which is why my trigger height is a tad different than before. I printed a calibration cube and put in the commands you suggested @dc42 this is the results:
                G10 P0
                Tool 0 offsets: X0.00 Y0.00 Z0.00, active/standby temperature(s): 0.0/0.0
                M290
                Baby stepping offset is 0.000mm
                G31 T5
                Threshold 500, trigger height 2.19, offsets X0.0 Y-40.0
                Everything looks good right?
                https://gyazo.com/e708fbecbdc5baf48ebf945f10f2fadf
                Notice the commanded position and the readout in the top right.
                I tried the suggestion by @Phaedrux and manually entered that move command ( verified Z 0, sent the G1 Z+10.00 F20000, then back to 0 and it was fine.)
                I have no idea whats going on. I haven't updated to 2.0 yet but I think it might fix whatever issue I might be having but I will wait to see what you all have to say.
                I really do appreciate the time you guys ( even though it may not be much time) put into helping me out.
                  It looks to me that you have some sort of bed compensation in use that is causing a 0.4mm adjustment. Please run M122 and see what the "Bed compensation in use" field reports.
                  Another possibility is that the GCode file you printed uses a M206 commands to offset the Z axis.
                    lolmodule
                    No bed compensation: https://gyazo.com/9193b8b3715ef0341789c3e7e04b06f3
                    Checked the last few files and there are no M206 commands. My start script does have an M207 that has a Z0.4 in it.
                    Could that be it? like I mention earlier I am not fully up on Gcode so when my friend gave me the scripts for FW retraction I just used them. Is there a reason to have a Z0.4 in the FW retraction?
                      The Z parameter for firmware retraction controls Z hop.
                        lolmodule
                        Ah ok. I dont know what the issue could be then... Everything appears to be setup right.
                          Might be time to give 2.0 a try.
                          If that doesn't work, you could try backing up all your existing config files from the /sys folder and then starting fresh with a new config bundle generated by the RepRap configurator. It would likely take some tuning and adjusting to get it working properly for your printer again, as the configurator really provides more of a starting point than a final working config. This would also give you a chance to dig into RepRap firmware and gcode a little more which is really quite powerful once you get into it.
                          I still suspect some binding or skipped steps occasionally, can you verify what the rated current for your z stepper is and whether you're running it at close to 85% of rated?
                            deckingman
                            I thought that the 20,000 mm/min (333mm/sec) for the Z move in the end gcode was way too fast (which it is) but then it'll be limited to 1,000 because that's what is in config.g.
                            Like Phaedrux, I'm also inclined to think it's binding or skipping steps. You could try lower Z acceleration.
                              lolmodule
                              It may be that, but like I posted above. I ran that high Accel z move manually and it returned to 0 no problem. ( But that doesn't mean it isn't the cause)
                                @lolmodule Just a theory, but at the end of the print the motor may be hot and may not respond the same.
                                lolmoduleundefined 1 Reply Last reply Reply Quote 0
                                  lolmodule @Phaedrux
                                  @phaedrux that's possible. I'm running dual leadscrew steppers for my Z so I didn't think it could be that but it's definitely not out of the realm of possibility.
                                    lolmodule
                                    I updated to 2.0. printed a calibration cube. removed the print and sent the head to X150 Y150 Z10 ( 10mm above the center of my bed) and this is the result...
                                    https://gyazo.com/384ec6ddfaa195b510a2755408a18a8c
                                    No more strange offset after a print!
                                    Thanks to everyone for all the help and tips!
