    12V on duetwifi + duex5
    • nraynaud
      nraynaud last edited by
      Hi all,
      I am about to pair my duex5 with my duet wifi and bring my input voltage to 24V.
      I can't find a good picture of the intended mechanical mounting of the 2 PCBs, is it simply back to back with standoffs? can people who went this route show me picture of their installation for inspiration please?
      I would like to get the 12V from the embedded duex5 power supply for my general 12V needs (I guess it's mostly fans) I can't seem to find a breakout pin to bring it back to the big duet wifi, did I miss something on the schematics?
      thanks all for your help.
      Dougal1957 1 Reply Last reply Reply Quote 0
        The intended mounting is either back to back using standoffs, or side-by-side with the VIN terminal blocks next to each other.
        Current DueX5 boards don't have a 12V output pin, however if you set the fan voltage selector jumper to 12V then you can pick up 12V from any of the fan ouputs connectors on the DueX.
        • Dougal1957
          Dougal1957 @nraynaud last edited by
          @nraynaud said in 12V on duetwifi + duex5:
          Hi all,
          Does this help I have used 20mm nylon M3 standoffs
          • nraynaud
            Thanks you all.
            dc42> may I suggest you break out the 12V with an actual 2A capable connector for the next revision? This is a really compelling power rail.
            dc42 1 Reply Last reply Reply Quote 1
              dc42 administrators @nraynaud last edited by
              Thanks you all.
              Already done!
