    Another Jerk Question
    • garisundefined
      garis
      I am now "commissioning" my 2nd Hypercube Evolution with a small build volume X 150 Y200 Z250. All motors and the Duet now operational.
      The X carriage is light with a Nimble, E3D & Volcano, 3 small 8mm linear bearings and some plastic. The Y mass includes the above plus 2 280mm x 8mm dia X rods, the Y carriages, & 2 long 10mm linear bearings - still fairly light but the X rods and Y bearings relatively much higher mass than the X carriage assembly. A heavy & rigid frame, and bed on 2 12mm Z rods.
      I am hoping this will print fast with PLA and the Volcano heat block - it will be fun finding out - for say rapid prototyping of small parts.
      My 2 questions:
      • 1: Can a Core XY have different Jerk and Acceleration settings for X and Y?
      • 2: Out of curiosity, how is Jerk implemented? Is a "large" pulse [ dependent on jerk and mass to be moved but limited by some stepper driver constraint although there would be no thermal issue for this time] sent to the motor to provide a steep acceleration ramp {before the normal acceleration} with the firmware planner function assuming it is instant?...
      • .......... and with the motor responding subject to its internal response rate and the printer responding subject to the elasticity of the X Y belts (in my case) and mass to be moved? and with some (undetectable! ) initial velocity oscillations about the standard acceleration ramp?
        dc42 administrators @garis
        @garis said in Another Jerk Question:
        Yes.
        The rate at which step pulses are sent to the motor is changed suddenly. Of course, the motor and the motion system cannot respond to this instantaneously; so there will be a temporary overshoot of the specified trajectory when the step pulse rate is reduced, and an undershoot when it is increased.
