M84: Stop idle hold ¶
Hi. I am using an extension board to drive external stepper driver. M84 is set to S30 in the config file but the motors stays in idle mode even after some minutes, causing the motors to get hot, but when I execute the M84 command manually the motors is released.
@jddt With
M84 Sxx
you set the timeout when motors are supposed to go into idle current state (not ending it). You set the idle current as a percentage withM906 Ixx
. Motors will never turn them off completely without user interaction. This interaction might beM84
which without any further parameters will do what the title says, it will stop the idle hold mode of the motors and shut them off. The same can be achieved by issuingM18
