Duet WIFI Z not working during print only!!! Layer not going up
  • Guys please help me! My Z axis not working ONLY during a print! I saw some people with this error but i didnt understood! im from brasil 🙂
  • ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
    ; generated by RepRapFirmware Configuration Tool on Mon Jun 18 2018 23:27:29 GMT-0300 (Hora oficial do Brasil)
    M667 S1 ; Select CoreXY mode
    M550 PJose Arthur Printer ; Set machine name
    M552 S1 ; Enable network
    M587 S"" P"" ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P2 S1 ; Drive 2 goes backwards
    M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
    M92 X80 Y80 Z400 E100 ; Set steps per mm
    M566 X900 Y900 Z10 E120 ; Set maximum instantaneous speed changes (mm/min)
    M203 X12000 Y12000 Z300 E3000 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z100 E5000 ; Set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E820 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X0 Y-50 Z0 S1 ; Set axis minima
    M208 X200 Y200 Z200 S0 ; Set axis maxima
    M574 X1 Y1 S0 ; Set active low endstops
    M574 Z1 S2
    M558 P7 H6 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
    G31 P20 X0 Y50 Z0 ; Set Z probe trigger value, offset and trigger height
    M557 X25:175 Y25:175 S20 ; Define mesh grid
    M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4725 C0 R4700 ; Set thermistor + ADC parameters for heater 1
    M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 ; Define tool 0
    G10 P0 X0 Y0 Z0.5 ; Set tool 0 axis offsets
    ; Automatic power saving
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
    T0 ; Select first tool
    Try homing the printer and then send the following commands alternately:
    G1 Z100 F10000
    G1 Z50 F10000
    That will test whether the speed and acceleration limits that you set in config.g are appropriate and working.
  • Thx so much for u reply. The Z work completely when its not printing. But in the print, it just print with xy and the Z dont move, i see layers number not going up to, its like 50% of the gcode done and i. Layer 1.... and theprint like a disaster.
    Please try that test. The speeds (F parameter) are deliberately very high and you may not have tested that yet.
    PS - also, after starting a print and getting this problem, run M208 to check that the Z movement limits are still correct.
  • @dc42 said in DUET WIFI Z NOT WORKING DURING PRINT ONLY!!! LAYER NOT GOING UP:
    M208
    M208
    Axis limits - X: 0.0 min, 200.0 max, Y: -50.0 min, 200.0 max, Z: 0.0 min, 200.0 max
    ALL working but z jjust dont work in print...
  • the problem is that it stay in layer 1 all print... print all gcode in the layer 1
    i tryed with other boards work with them...can u help me
    1. Have you checked that when you command the Z axis to move by (for example) 50mm, it really does move that amount and not by some lower amount?
    2. Please provide us with access to a GCode file that shows the problem.
  • It worked👍 Printing perfectly, the only problem its that my fan fuse come kind a bugged... i connected fan ans it burned realy crazy now im in brasil its kind hard to find one other... but iam in love with this boad... u kind a genius to make something sooo good!
    @josegerdes said in Duet WIFI Z not working during print only!!! Layer not going up:
    I'm glad you got it working.
    If the fan fuse blew then you probably connected the fan the wrong way round, or the fan was rated at a lower voltage than the power supply voltage.
    To find a replacement, try searching eBay for "1A mini blade fuse". Here are example listings from eBay UK:
    https://www.ebay.co.uk/itm/1A-1-Amp-ATM-Mini-Blade-AUTO-Fuse-12V-24V-32V-UKgtn-1-Lot-50-Pcs/200776875648
    https://www.ebay.co.uk/itm/12V-Assorted-Blade-Fuse-Standard-Micro-Mini-1A-40A-Car-Automotive-Fuses/263729461497
  • thx..! and u know a script with curl to automatcly upload file from simplify 3D
