    G32 sends crashes the bed agains the nozzle badly.
    • brunofportoundefined
      brunofporto
      I tried to use G32 command and it starts by homing all axis correctly as I configured at the homex.g files. The it deploys the probe and simply crashes badly the bed against the head (even broking my X carriage......) Then, with the Z motors still stuttering with force it moves the broken head to the first probing point configured at bed.g file....
      Please, what I am doing wrong?
      bed.g contents:
      G28 ; home all axes
      M98 Pdeployprobe.g ; deploy mechanical Z probe
      ; Probe the bed at 4 points
      G30 P0 X50 Y20 H0 Z-99999
      G30 P1 X50 Y260 H0 Z-99999
      G30 P2 X250 Y260 H0 Z-99999
      G30 P3 X250 Y20 H0 Z-99999 S
      M98 Pretractprobe.g ; retract mechanical Z probe
      • Danalundefined
        Danal
        What kind of printer? What kind of probe?
        Does triggering the probe with your finger (or similar) show up in the web interface?
          brunofporto
          Thank you Danal,
          It is a CoreXY machine (Hypercube Evolution) and uses a servo+optical endstop probe (https://www.thingiverse.com/thing:2890290).
          Manually trigerring of the probe works fine - also during home Z or home all as the probe is my Z_min endstop.
            brunofporto
            Problem solved!!!
            Added some time after the deployment of the probe at the deployprobe.g macro:
            G4 P300 ; Wait 0.3 sec.
