External G-Code control
  • I want to discuss how an external process like data from an Arduino can send and receive G-Code to Duet best. Examples are new sensors to control printing behavior (pause e.g.), timers to turn on /off LEDs at specified times, coordination of multiple printers by timing g-code execution etc.
    I see two possible solutions: executing DWC commands through the Ajax JavaScript in the command window or cloning this behavior. Or inserting the hardware into the SPI wire of the PanelDue and executing the G-Code the way PanelDue does it.
    Are those methods ok and are there other possibilities?
    The firmware can accept commands received via USB, the Panel Due serial port, http and Telnet. So take your pick. If you don't have a Panel Due connected, sending commands through the Panel Due port is probably easiest. The signal level is 3.3V and the protocol is standard 8-bit asynchronous without flow control. The default baud rate is 57600.
  • Thanks a lot David, so there are some options.
