    Will 12v fan on 24Vin blow up the board?
    fans setup mosfet pwm control
    • pro3d
      pro3d last edited by
      As subject says. I forgot to replace the fan and after power up there was something blowing up
      The 12v fan was connected to F0 and my vin is 24v 10A
      What kind of damage am I looking at? Mosfets only? More damage?
      Will all the pwm ports be affected by this?
      Are drop downs ok to use here?
      All pwm fans are now not controlled anymore but just always on full speed
        The only components likely to have been damaged are the mosfets and of course the fan.
        You mustn't use drop downs on the fan outputs (other than the always-on fan output), however you can remove the fan voltage select jumper and feed 12V into the centre pin in order to use 12V fans. However, 24V fans are readily available,.
        pro3d 1 Reply Last reply Reply Quote 0
        • pro3d
          pro3d @dc42 last edited by
          Thanks for the response! Not many radial 4020 blowers on 24v
          But can connecting wrong fan to one port destroy all of the FAN outs?
          Followup question
          I also connected the bl touch before making it 3.3v ready --- Are more components now dead?
            dc42 administrators @pro3d last edited by dc42
            @pro3d said in Will 12v fan on 24Vin blow up the board?:
            Shorting one fan output can damage a trace on older Duets, or blow the 1A fuse on revision 1.03 Duets. But in that case, the fans won't run at all.
            Followup question
            Unlikely. We can't guarantee it, but the endstop and Z probe inputs will generally tolerate a lot of over-voltage without damage.
