    Axis Maximal Movement (M208 equivalent) for a Delta?
    • SnowCrashundefined
      SnowCrash
      Is there a way to set the maximum travel movement on a Delta similar to the use of M208 for a Cartesian machine (only in this case it would be a maximum radius I guess)? I hesitate to change the printer's dimensions definition to achieve this as I don't know if it will affect other operational aspects.
      Thanks!
      • T3P3Tonyundefined
        T3P3Tony administrators
        use the "B" parameter isthing the M665 delta configuration Gcode:
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M665_Set_delta_configuration
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_M665_command
        Cheers
        Tony
        www.duet3d.com
        SnowCrashundefined 1 Reply Last reply Reply Quote 1
          SnowCrash @T3P3Tony
          Thanks @t3p3tony!
