Diamond + Kossel + DuetWifi
I have just started a project ti build a KosselXL with a diamond hot end with DuetWiFi + Duet2X. Any suggestion on what to look for or experience sharing is more than welcome!
Hey fpex
Have a look here:
https://www.duet3d.com/forum/thread.php?id=574#p5515and the associated blog post by Ian Pegg (deckingman)
http://blog.think3dprint3d.com/2016/12/using-diamond-hotend-with-duetwifi.html
Its on a corexy rather than a delta but there will be a lot of similarities and useful stuff.
…....and if you have any other questions that the blog post doesn't cover, post here and I'll be happy to help if I can. But as Tony pointed out, mine is a CorexY, and I know nothing about Delta's.
Thanks. I am starting mounting, but first i needed ti decommission an ormerod2. it was time.
anybody has an idea where I can find editable kossel plastic part files (15x15 extrusions)? I am not impressed by some parts and would love to change them.
have a look at our github:
https://github.com/T3P3/kosselthere a Johann's original kossel files, then some additions we made a long time ago, and the "Release 3" directory has further revisions we made more recently.
Thanks!
Now that i am a big piece forward I am facing a little problem. The two boards are quite large and the way the connectors are done it is impossible to put it in the base of a kossel (except when I give up height and make a much deeper base). The only options I see are either an external box with boards backt to back and push-pull fans in between. Or place them flat (next to each other) in the top of the printer.
For the latter I would need a shorter ribbon cable though.
