Heater Fault debug facility
  • most difficult issues (that i have faced and other people are facing) are heater fault. Even though there is wiki article it does not answer all questions.
    I suggest firmware would be much more informative in heater fault errors.
  • never faced a heater fault. And it is easy to fix those, 99% heater faults are electrical problems.
    @c310 said in Heater Fault debug facility:
    Please suggest what additional questions the wiki should answer.
    What additional information would you like the firmware to provide?
  • for debug issues i suggest to split (if possible)
    heater issues from termistor issues
    by the way is there any theoretical or practical chance that smatreffector (broken or crazy) is causing heater faults?
    The firmware can't always tell the difference. For example, if the temperature rises too slowly when heating is commanded, it could be caused by either a thermistor fault or a heater fault.
    Yes, if the heater or thermistor connector isn't properly soldered.
    1. What would help a lot would be a screenshot of the moment when the error occurs. For example, if the temperature drops by 30° within a second in the event of an error, it cannot be a Heater error, but must be a problem with the thermistor. because NO heatbed can drop 30° in that time. If theres a heater prob, the temp would fall more slowly.
    2. a menue point in the right mouse menue on the bed and tool heater to reset it would be nice.
  • in last case fault was issued by high temperature i think. pt100 is up to 500 degrees
    but RRF M143 command limits temp to 262 degrees and i was trying to print at 290.
    when tool was hot, and no print job - no errors so far. once i start print - heater fault immediately.
    i think it is RRF bug. it should not allow 290 deg 🙂 in such a config.
    to find the issue i removed all cables from the duet board, and connected heater and PT100 directly without heatsink ... took me 2 hrs to find 🙂
    i have added that to wiki on heater fault troubleshooting
  • With default settings, I was getting a heater fault whenever the model fan came on, as it would cause a dip in extruder temperature until the PID caught up. Had to greatly relax the fault detection. Should detect on temperature direction instead of anomaly from set temp?
    @r3cvr said in Heater Fault debug facility:
    A falling temperature may be caused by the heater or the thermistor falling out of the heater block. Either could cause a fire.
  • @r3cvr and what is wrong with that? One step of setting up a new printer is always do a PID tune.
  • @dc42 said in Heater Fault debug facility:
    But false positives lead to effectively disabling the feature?
    Is there any way to measure the resistance/power consumption of the heater? Could try and use the resistance as a secondary temp measurement and set thresholds for disabling. I'm assuming most heaters have some positive coefficient of resistance.
    @dragonn said in Heater Fault debug facility:
    Print fails with no extrusion after heater fault shuts down heater. That's how my first dozen or so print attempts on DuetWifi went. I actually have several PID tunes, done at different model fan settings. No surprise it comes up with different parameters. Doesn't help this issue that much.
  • @r3cvr They are no "false positives" when dealing with "thermal runaway". If it triggers then is something wrong with you hardware setup. It can by that you part cooling fan is to strong, it can be that you part cooling tunnel is wrong and blows on the heater block.
    First of all, I suggest isolating you block, even warping it with kapton tape helps much. And E3D silicon socks are just amazing.
    Don't blame software for problems with you hardware. 99% of users don't have any problems with current thermal runaway implementation in DuetWifi.
    Heaters usually use nichrome wire, which has a very low temperature coefficient of resistance, making it hard to use the element as a temperature sensor.
