    Homeall
    • Mike McGundefined
      Mike McG
      I got my new DuetWiFi A couple of days ago And I am getting an errorWhen I tried at home
      Error: G0/G1: insufficient axes homed
      Error: Pop(): stack underflow! New Error
      Any help would be appreciated Thanks
      • Patrickje1991undefined
        Patrickje1991
        What does you home gcodes consist off because you need to add some parameters when you want to move axis before they are homed.
        If you want to move a axis before homing you need to add S2 to the move G1.
        Example:
        ; Lift Z
        G1 Z10 F6000 S2
        With kind regards,
        Patrick
        XYZ Davincy 1.0 (Upgraded with: Duet Wifi/E3D V6/E3d Titan/Bowden/MK3 Alu. Bed)
        • deckingmanundefined
          deckingman
          ........or add M564 H0 to config.g to alow axes movement before homing has been carried out.
          • Anzereundefined
            Anzere
            Reprap firmware has protection in place to prevent you from crashing your printer in the form of a homing requirement. You can either home your printer or disable the homing requirement. In order to disable the homing requirement for your printer you can enter the command M564 H0 as stated by @deckingman.
