    WiFi unstable in Release 2.0/1.21?
    1.6k
    • tinkerzundefined
      tinkerz
      Spent a good portion of the evening last night fighting WiFi connectivity on the DuetWifi. Originally purchased the board in Oct 2017, had hooked it up to a single motor/rail to play with it while waited for the rest of the mechanical parts. Those parts never developed so I gave a printer a brain transplant with the DuetWifi last night (July 2018). That's when things went all wonky and the board wouldn't stay connected. Near the end I realized I had done all the updates to 2.0/1.21.1 shortly after bringing the board live as if I had just pulled it out the box. Doing the good dutiful thing of updating all the firmware. It then dawned on me finally that the connectivity issue hadn't been there before in Oct '17 so I got out a new SD card loaded it up with 1.19, reflashed all the firmware back to 1.19 and the unit is stable again. Not sure what's up with 2.0/1.21 but here are some of the M122 diag's I got back from it. I also have some pics of the PanelDue console showing that it was disconnecting and reconnecting every few minutes. In the troubleshooting process I had stripped the board down to just the board and power, and in fact used 2 different power supplies and even just powered the board via a 5v battery over USB for a bit, because I thought I was chasing ground loops or bad/noisy motors, all sorts of things in the connectivity troubleshooting. In the end rolling back to 1.19 resolved everything. I'm not sure if my board is of the age it can't be upgraded to the latest firmware or what but hopefully the attached M122 queries will shed some light.
      Thanks for your time,
      Keith
      9:21:50 PMM122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DDM-9FAM2-LW4S4-6JTD0-3SN6N-T2VZY
      Used output buffers: 3 of 20 (8 max)
      Static ram: 28380
      Dynamic ram: 95740 of which 0 recycled
      Exception stack ram used: 284
      Never used ram: 6668
      Task NETWORK ready, free stack 440
      Task HEAT blocked, free stack 1256
      Task MAIN running, free stack 3624
      Last reset 00:01:08 ago, cause: reset button or watchdog
      Last software reset details not available
      Error status: 0
      Free file entries: 10
      MCU temperature: min 31.6, current 37.0, max 37.0
      Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0
      Date/time: 2018-07-10 21:21:50
      Slowest loop: 3.73ms; fastest: 0.07ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 14.22ms; fastest: 0.01ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21
        WiFi MAC address 2c:3a:e8:0a:f5:5f
        WiFi Vcc 3.35, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 15960
        WiFi IP address 192.168.1.95
        WiFi signal strength -49dBm, reconnections 0, sleep mode modem
        Failed to request ESP stats
        === Expansion ===
        9:21:44 PMConnection established!
        9:15:04 PMDisconnected.
        9:14:45 PMM122
        Used output buffers: 1 of 20 (13 max)
        Static ram: 28380
        Dynamic ram: 95784 of which 0 recycled
        Exception stack ram used: 356
        Never used ram: 6552
        Task NETWORK ready, free stack 460
        Task MAIN running, free stack 3560
        Last reset 00:02:41 ago, cause: reset button or watchdog
        Error status: 0
        MCU temperature: min 38.6, current 39.3, max 39.5
        Supply voltage: min 23.9, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0
        Driver 0: standstill, SG min/max 0/216
        Driver 2: standstill, SG min/max 0/589
        Date/time: 2018-07-10 21:14:45
        Slowest loop: 9.64ms; fastest: 0.08ms
        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 238, MaxWait: 4294915897ms, Underruns: 0, 0
        Scheduled moves: 10, completed moves: 10
        Segments left: 0
        === Network ===
        Slowest loop: 3.01ms; fastest: 0.07ms
      • WiFi -
        WiFi flash size 4194304, free heap 15640
        WiFi signal strength -47dBm, reconnections 0, sleep mode modem
        === Expansion ===
        9:12:21 PMM122
        Static ram: 28380
        Last reset 00:00:17 ago, cause: reset button or watchdog
        Error status: 0
        MCU temperature: min 36.7, current 38.8, max 38.9
        Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0
        Date/time: 2018-07-10 21:12:20
        Segments left: 0
        === Network ===
        Slowest loop: 14.25ms; fastest: 0.01ms
      • WiFi -
        Failed to get WiFi status
        === Expansion ===
        9:12:14 PMConnection established!
        9:11:16 PMDisconnected.
        9:02:48 PMConnection established!
        9:02:25 PMDisconnected.
        9:02:09 PMConnection established!
        8:56:48 PMDisconnected.
        8:56:38 PMConnection established!
        8:55:52 PMDisconnected.
        8:55:40 PMConnection established!
        Can you try assigning the Duet a static IP address that is acceptable to your router? The IP address is an optional parameter in the M587 command.
        • tinkerzundefined
          tinkerz
          Thank you for the response, I will try that down the road. For the moment I'm happy the board is operational and the machine is running so I don't want to go back down that rabbit hole at the moment.
          • T3P3Tonyundefined
            T3P3Tony administrators @tinkerz
            @tinkerz are you still having connection issues?
            www.duet3d.com
            tinkerzundefined 1 Reply Last reply Reply Quote 0
            • tinkerzundefined
              tinkerz @T3P3Tony
              @t3p3tony Yes, very much so. I did order another DuetWifi for another system and to further troubleshoot I've placed the new board in place of the old one. And no connection issues so far. Significantly more stable. No loss of connection via USB, no drops via wifi, no issues communicating with the PanelDue. All comms instability has disappeared. Looks to be pointing to an issue on the board. GIven the number of times I've updated it. downgraded it and even completely erased it and reinstalled everything I'm beginning to suspect it's the board.
                If the new board works much better than the old one in exactly the same machine, there could be a problem with the WiFi module on the old board. Do you know anyone with hot air desoldering equipment who could replace it? It should also be possible to replace it using a soldering iron and ChipQuik, but that's not something I have tried.
                • tinkerzundefined
                  tinkerz
                  Thanks for getting back so fast. Agreed, I believe the whole issue on the old board is the WiFi module. If you were to send a replacement for that I'll get it swapped out, whether it be giving the ChipQuik a try for the experience or having someone with desoldering equipment do it I'll get it accomplished.
                    The WiFi module is an ESP-12S, readily available at low cost on eBay; or you can use the ESP-07S + external antenna instead if you prefer. Make sure you get the S version. Your board is older so it may have the ESP-12F instead; but the -12S is fully compatible and is claimed by the manufacturer to perform better.
                    • tinkerzundefined
                      tinkerz
                      Thanks, will do. Though I was hoping to get that module replaced under warranty. Yes I know it's outside the 6 month window but the board did sit quite some time before I got to use it to the point where I could see it had problems. Just hoping for a little good will on the replacement. If not, no worries!
                      Also, a quick question regarding the external antenna WiFi, can the Duet board be ordered with that installed, or is there a product variant without the WiFi chip installed so that we can add the antenna mount version? Asking for future development as it was posed to me by other engineers being concerned about essentially locking the board inside a faraday cage by burying it inside a box of metal. Or will we just need to plan to desolder and resolder each one?
                      Thanks again,
                      Keith
                        To send you a replacement WiFi module, we'd first need to have our assembly subcontractor send us one, then send it on to you which could take a while and involve customs paperwork depending on which country you are in. As it's such a low cost item, it probably makes more sense for you to source it locally. If you are in the UK and can accept a 12F instead of a 12S, then I can send you one FOC.
                        • tinkerzundefined
                          tinkerz
                          That all makes sense. More hassle than it's worth. Thanks for the transparency.
                          Keith
                          • tinkerzundefined
                            tinkerz
                            Greetings all! Operation WiFiSwap via ChipQuik was a success. Board seems significantly more responsive and stable now. I'll have a better idea once I upgrade the Zortrax M300 with it. But for now I'm happy to report that a WiFi module can be desoldered via ChipQuik and a new one installed.
                            Maybe some documentation on this would be nice. Or at least let people know to copy the DuetWiFiServer.bin file to the /sys folder and perform a M997 S1 to get the WiFi chip firmware loaded. Initially I was a bit sad to only see the light flicker once on the WiFi module. But once I tried poking it with commands I started to get the feeling it might not know how to respond appropriately so I flashed it's firmware. And all set. Connected!!
                            Yay! Thanks again folks.
                            Keith
                            • hayseed_byteundefined
                              hayseed_byte
                              This is interesting to know. And external antenna would solve a lot of my problems, I think.
                              https://wildbot.me/wildbot
                              Gcode Definitions for VSCode extension: https://github.com/hayseedbyte/rrf-gcode-definitions
