    Laser Filament Monitor - test results
    Filament Monitor
    16
    139
    20.9k
      dc42 administrators @kraegar
      @kraegar said in Laser Filament Monitor - test results:
      What wavelength is the IR?
      850nm.
      • fmaundefined
        fma
        Another result, with Dailyfil Dark gray PLA: https://www.filimprimante3d.fr/filament-pla-175-mm/1479-pla-175mm-dailyfil-gris-fonce-1kg.html
        Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 140%, check every 3.0mm, current position -1.7, brightness 92, shutter 17, measured minimum 89%, average 97%, maximum 109% over
        9032.8mm
        Soon a result with their blue PLA ("Tardis RAL")...
        Frédéric
        • fmaundefined
          fma
          Dailyfil Dark blue (aka 'Tardis') PLA: https://www.filimprimante3d.fr/filament-pla-175-mm/1483-filament-bleu-fonce-dailyfil-pla-1kg-175-mm.html
          Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 140%, check every 3.0mm, current position -9.5, brightness 94, shutter 17, measured minimum 60%, average 97%, maximum 131% over 15377.6mm
          Frédéric
          • wilrikerundefined
            wilriker
            I did some more prints with the same configuration as before and added them to my Google Spreadsheet. I also added a new column whether this has been done at night or at day.
            Interesting is that contrary to @T3P3Tony's theory I get slightly better results at daytime than at night with just a small light (halogen lamp). It's not much of a difference but consistent.
            Unfortunately of the three prints I did today I forgot to take the data from the first one (added M591 D0 to the end codes meanwhile) and the third one was cancelled due to a recurring heater fault on my hotend (temperature rising much slower than the expected 1.8°C/sec). I have to investigate what is happening there first. 😠
            Manuel
            My Tool Collection
            • T3P3Tonyundefined
              T3P3Tony administrators @wilriker
              @wilriker thanks, that is interesting. I do wonder what caused the obvious improvement in the results over time...
              www.duet3d.com
              • Guyarosundefined
                Guyaros
                Hi all,
                Thanks for your feedback.
                I designed an improved sensor housing (V2).
                I have printed it and tested the sensor fit, but I didn't have time to test the sensor yet.
                If anyone wants to print and test this, please go ahead.
                I designed this to be a very fast and simple print and should be universally easy to mount because I included top and side holes.
                Here is a link to download the STL file:
                Laser Filament Sensor Housing - Thingiverse
                T3P3Tonyundefined 1 Reply Last reply Reply Quote 2
                • T3P3Tonyundefined
                  T3P3Tony administrators @Guyaros
                  @guyaros thats great, thanks!
                  www.duet3d.com
                  • fmaundefined
                    fma
                    As reflections seem to be an issue, I would design an enclosure with a big hole behind the filament, and then try different things. For exemple, il should work fine at night. But it would need something to block the incoming IR during day. Several materials could be tests, then, without changing the enclosure. Maybe the distance could be enough?
                    Frédéric
                    T3P3Tonyundefined Guyarosundefined 2 Replies Last reply Reply Quote 0
                    • T3P3Tonyundefined
                      T3P3Tony administrators @fma
                      @fma thats what the option to have the back open in the enclosure is there for in both designs. Also on the one i link from the documentation you can set the hole to be divergent to reduce the reflection. What we are not sure about is how much reflections case and issue. Also @wilriker has had some results that indicate external IR due to daylight may not be much of an issue.
                      www.duet3d.com
                      • LumberjackEngineeringundefined
                        With regard to external light, the NIR wavelength this sensor is using will get blocked by essentially anything that blocks visible light.
                        The reflectivity gets a little bit weirder though - if I remember when I get home, I'll try to do some digging. I can say that black probably isn't going to be the best choice as a lot of black pigments can suddenly turn reflective once you get above visible wavelengths.
                        • Guyarosundefined
                          Guyaros @fma
                          @fma In my sensor housing design, the sensor window can be completely closed using M4 screw.
                          Its also make it easy to check if the IR from the surrounding is interfering with the sensor.
                            Has anyone tried my earlier suggestion of a closure that is cone shaped on the inside?
                            • wilrikerundefined
                              wilriker
                              Something related to the guide at dozuki: It states that one should use M3x16 screws and nyloc nuts. I am using the open top (which is still thinner than the closed top) and the 9mm base and I could barely screw regular nuts on M3x20 screws. I could of course have used nyloc nuts but the threads of the screw would not have gone deep enough into the nut to make it to the nylon ring. I am using nylon washers underneath the nuts though. But anyway M3x16 would not have even protruded from the housing in my case.
                              Manuel
                              My Tool Collection
                              • T3P3Tonyundefined
                                @wilriker Thanks updated
                                @dc42 The housing design I shared has a divergent light path where the amount it diverges can be edited. Its has a square rather than round profile though.
                                www.duet3d.com
                                wilrikerundefined 2 Replies Last reply Reply Quote 0
                                • wilrikerundefined
                                  wilriker @T3P3Tony
                                  @t3p3tony said in Laser Filament Monitor - test results:
                                  Do updates in dozuki pages take a while? I cannot see any difference. 😕
                                  Manuel
                                  My Tool Collection
                                  • wilrikerundefined
                                    wilriker @T3P3Tony
                                    @dc42 Also in what direction is that cone/divergence supposed to be according to your suggestion (that I apparently missed and cannot find either)? Tip towards the sensor or away from the sensor?
                                    EDIT: Of course if it is tip towards the sensor it would not make sense to have full cone since it would block the sensor. In that case I would assume a cone with the top chopped off.
                                    Manuel
                                    My Tool Collection
                                    • T3P3Tonyundefined
                                      @wilriker have a look at this:
                                      Having a divergent light path to reduce stray reflections back to the sensor might help, See the "divergeAmount" variable in the OpenSCAD design on youmagine.
                                      From the documentation
                                      www.duet3d.com
                                      • wilrikerundefined
                                        wilriker @T3P3Tony
                                        @t3p3tony Now I am confused 😕
                                        I thought your "Thanks updated" was related to me reporting that I found the screw lengths given in the documentation to be too short.
                                        Re: housing: I already have your scad file on my hard drive and looked into it. My question on the direction of the cone that @dc42 suggested was that it could be he meant to have the base of the cone starting at the sensor going into its tip in direction of the top housing part so that in the end it looks like the top housing has some kind of spike. I would assume that this is to keep the light deflecting internally in various directions until it is too faint to detected by the sensor anymore. But that is just an assumption.
                                        Manuel
                                        My Tool Collection
                                          dc42 administrators @wilriker
                                          @wilriker said in Laser Filament Monitor - test results:
                                          Yes, that is what I intended.
                                          • wilrikerundefined
                                            wilriker @dc42
                                            @dc42 said in Laser Filament Monitor - test results:
                                            So I came up with
                                            Top View:
                                            top view
                                            Bottom View:
                                            bottom view
                                            Sorry for those screen-caps, my OpenSCAD only produces fully-black PNG files when trying to export the design as an image.
                                            Manuel
                                            My Tool Collection
