    How to place dual Zmax endstop/flag accurately?
    • AlexLin
      AlexLin last edited by
      Hi
      Currently I use the z probe to do bed leveling(and mesh comp) on my core XY. I'm thinking about installing 2 Zmax end stop and homing to max (temporarly using independend axis when homing). This would be better for power failure recovery.
      However with the probe I'm sure a tilted bed or some way tilted x axis is accounted for. How do I make sure both of the Zmax endstops/flags are in exactly the right place so the bed surface is level in respect to the x/y plane? Just measuring with a tape doesn't feel accurate enough.
      • T3P3Tony
        T3P3Tony administrators @AlexLin last edited by
        @alexlin one option may be to use a finely adjustable trigger mechanism (like an M3 screw). Then use the probe next to each Z axis to accurately set Z0 and move up a set distance and adjust the trigger so that is just triggers after a set move up ( on both sides)
        Duet Hardware Designer
        www.duet3d.com
          I use a macro to help me calibrate the zmax distance for my optical endstop. I think it should work just as well to adjust 2 endstops.
          I use this mount for my optical endstops which uses an M3 bolt for adjustment.
          https://www.thingiverse.com/thing:2070697
          After mechanically level the bed, and measuring the z probe offset, I run this to calibrate zmax height.
          ; 0:/macros/Bed Leveling/0_Measure Zmax trigger.g
          ; Automates measuring the Zmax trigger for optical endstop at 300mm
          M291 P"This will set Z0 and calibrate Zmax height to 300mm" R"Proceed?" S3
          M291 P"Homing all axis" T5
          G28			; Home all
          G90			; Absolute positioning
          M98 P"0:/macros/0_Center Nozzle.g"	; Move nozzle to bed center
          M291 P"Adjust nozzle height until it's touching bed" Z1 S3
          G92 Z0 			; set Z0
          M291 P"Bed will now drop to Z300" S3
          G1 Z300			; Move bed down 300mm
          M291 P"Adjust optical endstop flag until light just turns off" R"Set Zmax=300mm" S3
          M291 P"ZMax homing will now be tested, starting with homing Zmin" S3
          M291 P"Homing to Zmin" T5
          G28 Z
          M291 P"Ready to test Zmax homing?" R"Proceed?" S3
          M291 P"Homing to Zmax" T5
          M98 P"0:/macros/2_HomeZMax.g" ; Test Zmax homing
          M291 P"ZMax homing test complete. Printer will now home all." R"Proceed?" S3
          G28	; Home all
          M291 "ZMax calibration complete." S3
          • AlexLin
            Thanks for useful tips!
              Another user with dual Y endstops splits them into Y and U for homing, then after the G1 S1 Ynn Unn move he/she sends a G1 Uxx command, where xx is a small correction to account for the two endstops not being perfectly aligned with each other. I know this because it exposed a bug! [Fixed in firmware 2.01beta2].
