    Endstop compensation
    1513
    • AV13091
      AV13091 last edited by
      Hello everyone,
      I decided to calibrate my delta printer. I already used Autocalibration to find out different adjustement :
      M665 L269.000 R164.761 H299.868 B140.0 X-0.386 Y-0.075 Z0.000
      M666 X0.703 Y-0.304 Z-0.399 A0.00 B0.00
      Given that I want to calibrate it from the start I decided to cancel endstop adjustement :
      M665 L269.000 R164.761 H299.868 B140.0 X0 Y0 Z0
      M666 X0 Y0 Z0 A0.00 B0.00
      The idea was to calibrate the spring's bed without any compensation on my tower (X,Y and Z endstop compensation).
      The problem is that even without any compensation in the config.g file I can see my printer making this compensation after homing (X doesn't move while Y and Z go further).
      Furthermore, this "compensation" is way more than what we can read (should be less than 1 mm but I can see that it's more like 3 to 5 mm).
      I tried to cancelled compensation (M561).
      Note that I do not use the M501 command at the end of my config.g (so the "config-override.g" do not modify my configuration).
      Can someone explain me why my printer still do this compensation and how to delete this ?
      Thanks for your help.
      Axel.
        @av13091 said in Endstop compensation:
        I'm sorry, I don't understand what you mean by this. Please explain.
        • AV13091
          If I'm correct, the homing works in 3 steps on delta printer : full speed to the top until reaching the endstop, go down and then up at lower speed until reaching endstop again and, finally, all carriages go down a bit more (it's 5mm by default in the home.g file if I'm right).
          At this point the compensation is done by modifing carriage's position (if compensation is X0, Y1 and Z3 the X carriage wont move, the Y carriage will go 1mm down and the Z will go 3mm).
          My problem is that even without any compensation I can see that my printer does this "correction" after homing (X stay at his initial position but Y and Z go down), it's not "a little movement", it's something more like 1 or 2 mm.
          I'm sorry if I wasn't clear enough and I hope this will help you understand what's going on.
          Don't mind to ask again if it's not clear (I'm not that good with english when it happends to explain this kind of stuff 😞 ).
          Thank you for your support.
          Axel.
            The tower angle adjustments (X and Y parameters in the M665 command) will also cause the centre position to be adjusted. So try clearing those out too.
            • AV13091
              it didn't work either, M665 X,Y and Z are deleted and M666 X, Y and Z values are clear :
              do you have any idea what goes wrong ?
              once again, thank you for your help.
                Please post your homedelta.g file.
                It should end with a "G1 X0 Y0" move. If you comment that line out, what XY coordinates does DWC report, and what M665 and M666 parameters does it report?
                • AV13091
                  you're right, it's the "G1 X0 Y0" move that make this !
                  when it's line out DWC report me X9,5 Y-0,5
                  M665 report me (...), X 1.075°, Y 1.130°, Z 0.000° and
                  M666 Endstop adjustments X-0.34 Y0.74 Z-0.40, tilt X0.00% Y0.00%.
                  It's amazing, thank you for your help !
                  If you have the time to, could you explain me why it does this ?
                  once again, thank you for your assistance and your patience.
                  Axel.
                    dc42 administrators @AV13091 last edited by
                    So you didn't reset the endstop adjustments and tower angles to zero after all. Could it be that you have two sets of M665 and M666 parameters in config.g and you only changed the first one?
                    • AV13091
                      Sorry, it's my bad, I just realised i did an auto calibration before sending this to you (I can print little part without problem even if my bed is not well calibrate).
                      So in my config.g file it's well put to zero :
                      sorry for the mistake,
                      Axel.
                        OK, what do M665 and M666 report after homing if you don't auto calibrate, and what are the XY coordinates when you don't execute the G1 X0 Y0 in homedelta.g ?
                        • AV13091
                          Without any auto calibration i got
                          DWC report : X9 and Y0
                          M665 : Diagonal 269.000, delta radius 164.761, homed height 299.868, bed radius 140.0, X 0.000°, Y 0.000°, Z 0.000°
                          M666 : Endstop adjustments X0.00 Y0.00 Z0.00, tilt X0.00% Y0.00%
                            The X9 is wrong, unless you have a tool offset configured in config.g. Please post your entire config.g file.
                            • AV13091
                              I use an offset for my extruder, well see ! (I have a chimera with only one extruder for now, I plan to mount the second in a few week).
                              As you expected their is an offset of X=9, what a coincidence 😄 !
                              As you've ask for, here is my config.g :
                              ; Configuration file for Duet 0.8.5 (firmware version 1.17 to 1.19)
                              ; generated by RepRapFirmware Configuration Tool on Fri Mar 16 2018 19:46:10 GMT+0100 (Paris, Madrid)
                              ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
                              M665 L269.000 R164.761 H299.868 B140.0 ; Set delta radius, diagonal rod length, printable radius and homed height
                              M666 X0 Y0 Z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
                              M550 PDelta Kossel ; Set machine name
                              M551 PAvoriaz2804 ; Set password
                              M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
                              M552 P192.168.0.90 S1 ; Enable network and acquire dynamic address via DHCP
                              M586 P0 S1 ; Enable HTTP
                              M586 P1 S0 ; Disable FTP
                              M586 P2 S0 ; Disable Telnet
                              M92 X80 Y80 Z80 E87.059 ; Set steps per mm E476.5
                              M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
                              M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
                              M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
                              M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent AVANT 1200
                              M84 S30 ; Set idle timeout
                              M208 Z-0.1 S1 ; Set minimum Z
                              M574 X2 Y2 Z2 S1 ; Set active high endstops
                              M558 P1 X0 Y0 Z0 H4 F120 T4000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                              G31 P500 X0 Y0 Z2.90 ; Set Z probe trigger value, offset and trigger height
                              M557 R85 S20 ; Define mesh grid
                              M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                              M307 H1 A271.6 C131.5 D4.8 S1.00 B0 ;
                              ; M307 H2 A271.6 C131.5 D4.8 S1.00 B0 ;
                              M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                              M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                              ; M305 P2 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 2
                              ; M143 H2 S280 ; Set temperature limit for heater 2 to 280C
                              M106 P1 T45 H1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned ON : 45°C
                              M563 P0 D0 H1 ; Define tool 0
                              G10 P0 X9 Y0 Z0 ; Set tool 0 axis offsets
                              ; M563 P1 D0 H2 ; Define tool 1
                              ; G10 P1 X-9 Y0 Z0 ; Set tool 1 axis offsets
                              ; G10 P1 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
                              T0 ; Select first tool
                              ; T1 ; Select second tool
                              If I'm right I have to make it X=0 in my tool section ?
                                So the "compensation" that you reported is caused by the firmware bringing your offset nozzle to be above bed centre. This is as expected, if you have Tool 0 selected when you home the printer. If you do not have a tool selected (for example, you send T-1 before homing), then it will not centre the nozzle.
                                • AV13091
                                  thank you for your help, I wouldn't find this out without you !
                                  Have a good day,
                                  Axel.
