    Nema selection?
    702
    • Falkia
      Falkia last edited by
      I have read the Wiki about how to choose type of stepper motor for my Delta printer but I'm not sure what way to go. My plan is to design a larger Delta (1500mm high), I know that the size of the printer doesn't matter so much when choosing motors but the guide carriages will be made of metal instead of plastic so a little bit heavier than ordinary. Printing speed maybe up to 200mm/s.
      My hardware is Duet 2 Wifi and 24v supply. I also want to use 0.9 degree motors.
      I have been looking at these two:
      17HM192004S
      Motor Type: Bipolar Stepper
      Step Angle: 0.9 deg
      Holding Torque: 46Ncm(65.1oz.in)
      Rated Current/phase: 2.0A
      Voltage: 2.8V
      Phase Resistance: 1.4ohms
      Inductance: 3.0mH ± 20%(1KHz)
      23HM22-2804S
      Manufacturer Part Number: 23HM22-2804S
      Step Angle: 0.9 deg
      Holding Torque: 1.26Nm(178.4oz.in)
      Rated Current/phase: 2.8A
      Voltage: 2.5V
      Phase Resistance: 0.9ohms
      Inductance: 4.5mH ± 20%(1KHz)
      Please give me some advise.
      Thanks
      Fredrik
      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
      • Hergonoway
        Hergonoway last edited by
        I've got the first ones, works like a charm on my 1m delta.
        The real "problem" on a delta is the weight, not stepper motor capabilities. Heavier carriage will engage more inertia, and pendulum effects 🙂 I had at first home made laser cut carriages, had a lot of quality issues (ringing, etc) within speed. Then I've switch to homemade plastic carriage and end rails tensioner, switch to 9mm belt and now it's top perfect.
        Delta goes BrrrRRRRrrrrrRRRRrrr
        Falkia 1 Reply Last reply Reply Quote 0
        • Falkia
          Falkia @Hergonoway last edited by
          @hergonoway
          Thanks for the input. What type of belts did you have before the 9mm? And what size of pulleys did you end up with?
          Hergonoway 1 Reply Last reply Reply Quote 0
          • wilriker
            wilriker Moderator last edited by wilriker
            In Recomendation of stepper motors... @MSquared also listed Wantai's 42BYGHM810 which is probably as good as it can get regarding resistance and inductance.
            Step Angle: 0.9 deg
            Holding Torque: 42Ncm
            Rated Current/phase: 2.4A
            Voltage: 1.92V
            Phase Resistance: 0.8ohms
            Inductance: 1.8mH
            Length: 48mm
            Manuel
            My Tool Collection
            Falkia 1 Reply Last reply Reply Quote 1
            • Hergonoway
              Hergonoway @Falkia last edited by
              @falkia at first I had standard 6mm GT2, I've ended up with 9mm GT2 with 10mm 20teeth pulley
              • Falkia
                Falkia @wilriker last edited by
                @wilriker
                Good spec on that one. Thanks
                • DADIY
                  DADIY last edited by DADIY
                  I'm using the 17HM19-2004S motors on my 1.7m tall Delta without issues, I wanted to use linear rails but was unable to source them. Ali express sellers said they had them but they let me down wanting more money and robotdig went out of stock after I ordered. I ended up with 3d printed carriages (the think3d ones) and v tracked delrin wheels. These worked well with the smart effector kit.
                  This was the carriage - https://github.com/T3P3/kossel/blob/master/Release3/STLs/R3-Vroller-adapter-V02.stl
                  • Falkia
                    Thanks everyone. I just ordered a set of 5 42BYGHM810. It was cheaper to buy a set instead of 1x3.
