Cannot upload files in duet wifi
@phaedrux Yes and now I cannot open WizFi on my Coputer. Been reading other situations and get more confused as I go. Can see in pronterface these commands:
M552 S1
SENT: M552 S1
RECV: Turn off the current WiFi mode before selecting a new one
RECV: ok
SENT: M105
RECV: ok B:2000.0 /0.0SENT: M105
RECV: ok B:2000.0 /0.0M122
SENT: M122
RECV: === Diagnostics ===
RECV: RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta2(RTOS) running on Duet WiFi 1.02 or later
RECV: Board ID: 08DGM-956GU-DJMSN-6J1DG-3SJ6R-9ANRF
RECV: Used output buffers: 1 of 20 (9 max)
RECV: === RTOS ===
RECV: Static ram: 28484
RECV: Dynamic ram: 95596 of which 0 recycled
RECV: Exception stack ram used: 308
RECV: Never used ram: 6684
RECV: Tasks: NETWORK(ready,1872) HEAT(blocked,848) MAIN(running,3736)
RECV: Owned mutexes:
RECV: === Platform ===
RECV: Last reset 00:13:53 ago, cause: reset button or watchdog
RECV: Last software reset at 2018-07-23 11:28, reason: User, spinning module GCodes, available RAM 7840 bytes (slot 1)
RECV: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0xffffffff
RECV: Error status: 0
[ERROR] Error status: 0RECV: Free file entries: 10
RECV: SD card 0 detected, interface speed: 20.0MBytes/sec
RECV: SD card longest block write time: 0.0ms, max retries 0
RECV: MCU temperature: min 34.9, current 35.3, max 35.5
RECV: Supply voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0
RECV: Driver 0: standstill, SG min/max not available
RECV: Driver 1: standstill, SG min/max not available
RECV: Driver 2: standstill, SG min/max not available
RECV: Driver 3: standstill, SG min/max not available
RECV: Driver 4: standstill, SG min/max not available
RECV: Date/time: 1970-01-01 00:00:00
RECV: Slowest loop: 0.18ms; fastest: 0.08ms
RECV: === Move ===
RECV: Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
RECV: Scheduled moves: 0, completed moves: 0
RECV: Bed compensation in use: none
RECV: Bed probe heights: 0.000 0.000 0.000 0.000 0.000
RECV: === Heat ===
RECV: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1
RECV: Heater 0 is on, I-accum = 0.0
RECV: === GCodes ===
RECV: Segments left: 0
RECV: Stack records: 0 allocated, 0 in use
RECV: Movement lock held by null
RECV: http is idle in state(s) 0
RECV: telnet is idle in state(s) 0
RECV: file is idle in state(s) 0
RECV: serial is ready with "M122" in state(s) 0
RECV: aux is idle in state(s) 0
RECV: daemon is idle in state(s) 0
RECV: queue is idle in state(s) 0
RECV: autopause is idle in state(s) 0
RECV: Code queue is empty.
RECV: === Network ===
RECV: Slowest loop: 0.18ms; fastest: 0.01ms
RECV: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
RECV: HTTP sessions: 0 of 8
RECV: - WiFi -
RECV: Network state is starting
RECV: WiFi module is disabled
RECV: Failed messages: pending 0, notready 0, noresp 0
RECV: Socket states: 0 0 0 0 0 0 0 0
RECV: === Expansion ===
RECV: ok -
@ngwpower said in Cannot upload files in duet wifi:
RECV: WiFi module is disabledThat combination (network stuck in Starting state) if it persists suggests a version mismatch between the main firmware and the WiFi firmware. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_How_to_recover_if_the_main_firmware_and_WiFi_firmware_versions_get_out_of_step_on_your_Duet_WiFi for how to recover from this.
@dc42 Thank You Sir. Got to this IP screen, could not for the life of me describe this accomplishment, just grateful it has occured and yes I belive in a higher power! Will proceed with details.
