    Unable to update PanelDue firmware
    PanelDue
    • pdundefined
      pd
      I have just tried to update my new PanelDue7i firmware and bossac reports it cannot find the device on the appropriate port.
      I carried out the normal procedure of erasing, restting, and then trying upgrade with bossac. The same procedure works properly on all my earlier versions of paneldue. I am using windows 10 and the only other novel feature is the the pc restarts when I pull the usb plug out. Presumably because the load is so high.
      Anyone any ideas?
        Perhaps you are using an old version of bossac? You need 1.8, the latest.
        • pdundefined
          pd
          Many thanks that was the problem
          • wmmc01undefined
            wmmc01
            I also having a problem, I get an error when I run the newest 64bit version: "Caught Unhandled, unknown exception, terminating". Also running running Bosac.exe from your github just quickly flashes a window and disappears. Win10. ANy other options?
            Qdeathstarundefined 1 Reply Last reply Reply Quote 0
            • Qdeathstarundefined
              Qdeathstar @wmmc01
              @wmmc01
              The bossac program needs to be ran via command line.
              https://miscsolutions.wordpress.com/paneldue/
              “Testing the board and updating the firmware”
              open command prompts, then run this command
              "C:\Program Files\BOSSA\bossac.exe" --port=COM9 -e -w -v -b PanelDueFirmware.bin
              changing the file path and file name and path as required.
