    G28 / G29 / G32 - confused when using 2 independent Z-Axis
    781
    • kuhnikuehnast
      kuhnikuehnast last edited by
      Hi!
      I am a littlebit confused at the moment and hope you can help me.
      I use 2 independent Z- axis (Stepper Driver 2 and 4) and want adjust a possible Z-axis difference in the calibration procedure. (The printer is a "Prusa-Style-Type")
      I now wanted to do it like this:
      1. G28 ; home all axis
      2. G32 S2 ; adjust the 2 Z-Stepper to be the same height
      3. G29 ; perform a mesh bed levelling
      4. printing.
      But if I perform it like this, the bed is always completely below the surface. None of the points are at 0. So I tried to perform a "second Z-Home" (G28 Z) bewteen 2 and 3. The effect was, that then the bed isn't any more flat on the points defined in G32... ? So what am I doing wrong?
      Here the "relevant" G-Code:
      config.g:
      M584 X0 Y1 Z4:2 E3 ; Define drive mapping- Z= driver number 2 and 4.
      M671 X-77:297 Y10:10 S3 ; Set position of the leadscrews
      G31 P25 X+26.9 Y5.935 Z0.905 ; Set Z probe trigger value, offset and trigger height
      M557 X20:200 Y20:200 S45 ; Define mesh grid
      home.z:
      G91 ; relative positioning
      G90 ; absolute positioning
      G1 X110 Y110 F6000 ; go to first probe point
      bed.g:
      M401 ; deploy mechanical Z probe
      G30 P0 X20 Y110 H0 Z-99999
      G30 P1 X200 Y110 H0 Z-99999 S2
      M402 ; retract mechanical Z probe
        What firmware version are you using? Also I don't see a M554 command. What type of z Probe are you using?
        kuhnikuehnast 1 Reply Last reply Reply Quote 0
        • kuhnikuehnast
          I only copied the relevant files for probing. I am using a BLTouch probe.
          • kuhnikuehnast
            kuhnikuehnast @Phaedrux last edited by
            @phaedrux said in G28 / G29 / G32 - confused when using 2 independent Z-Axis:
            You don't need a M554 command if you are connecting by M552...?
              Phaedrux Moderator @kuhnikuehnast last edited by
              @kuhnikuehnast I'm sorry, I meant M558 for probe configuration.
                Also, the reason I asked what firmware version is that there was a bug that could cause the mesh offset to be applied incorrectly leading to off first layers such as you describe.
                • kuhnikuehnast
                  I am on the actual firmware (2.0(RTOS) (2018-06-05b3))
                  The M558 is:
                  M558 P9 H5 F180 T15000 ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves
                    Try firmware 2.01 veta 2.
                    https://forum.duet3d.com/topic/6070/new-firmware-2-01-beta-2-available
                    Then rerun your bed leveling and probe offset measurements and see if your issue is resolved. Part of the problem was that M561 was not clearing the bed transformation as expected.
                      If that doesn't help, try adding this to the start of your print gcode
                      G29 S2 			; Disable bed compensation.
                      G29 S2 			; Disable compensation again.
                      G28 Z			; Home Z
                      G29 S1 			; Load heightmap.csv and enable compensation.
                      • kuhnikuehnast
                        But am I right with this procedure:
                        1. G28
                        2. G32
                        3. G29 ?
                          Yes I think so. You appear to be following the guidelines here: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                          There should be a final g28 z before starting a print to make sure you know where z0 is so that first layer height is accurate.
