    Adding an additional capacitor for Print Resume
    • pogo1213
      pogo1213 last edited by pogo1213
      Printer Setup
      30W hotend heater
      M906 X800 Y800 Z1200 E1200
      360W Heated Bed
      500W Mean Well power supply
      The issues that I have ran into is that there isn't enough power left to lower the bed (dropping Z) and move the head to the side at power loss.
      Easy solution- Larger power supply.
      Issue- I cant find a power supply to fit the footprint I have assigned to it (no I cant just put a larger one in there)
      Purposed solution- Make a daughter board that slots into the power supply terminals that has a large capacitor to allow for the use of Print Resume. There are three Line and Neutral post on the power supply the plan is to just add the capacitor to one set and and have outputs off the daughter board. The other two sets would just pass through the daughter board.
      Any ideas or thoughts on this? Reasons why it wont work?
        Do you mean "capacitor"?
        • pogo1213
          Yes sorry I mean capacitor
            Yes that should work. Or you could use 2 sets of output terminals to power the Duet and the third set to connect the capacitor.
