    Auto Bed Compensation - Too Slow?
    1308
    • ajcraig99
      ajcraig99 last edited by
      I have just installed a peizo probe on a new printer build and have got my homeall.g working nicely with the peizo triggering as expected. It is installed in the hotend mount and installed in a titan extruder.
      When I use the Auto Bed Compensation tool to call G32, it probes too slowly which i believe is the reason for it not triggering the Peizo.
      The issue might be in the zprobe section of my config.g but I don't have a strong enough understanding to debug it or understand the code fully.
      Here is my bed.g
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool on Sat Jul 21 2018 13:51:16 GMT+1200 (New Zealand Standard
      Time)
      G28  ; home all axes
      ; Probe the bed at 5 points
      G30 P0 X15 Y15 F6000 H0 Z-99999
      G30 P1 X15 Y285 F6000 H0 Z-99999
      G30 P2 X305 Y285 F6000 H0 Z-99999
      G30 P3 X305 Y15 H0 Z-99999
      G30 P4 X160 Y150 H0 Z-99999 S**
      And here is my config.g
      Standard Time)
      G90                               ; Send absolute coordinates...
      M83                               ; ...but relative extruder moves
      M667 S1                           ; Select CoreXY mode
      M550 PLinBot                      ; Set machine name
      M552 S1                           ; Enable network
      M587 S"ASUS" P"Fe7awrEpMade2race" ; Configure access point. You can delete this line once connected
      M586 P0 S1                        ; Enable HTTP
      M586 P1 S0                        ; Disable FTP
      M586 P2 S0                        ; Disable Telnet
      M569 P0 S1                        ; Drive 0 goes forwards
      M569 P1 S1                        ; Drive 1 goes forwards
      M569 P2 S1                        ; Drive 2 goes forwards
      M569 P3 S1                        ; Drive 3 goes forwards
      M350 X16 Y16 Z16 E16 I1           ; Configure microstepping with interpolation
      M92 X80 Y80 Z2395 E420           ; Set steps per mm
      M566 X900 Y900 Z12 E120           ; Set maximum instantaneous speed changes (mm/min)
      M203 X9000 Y9000 Z600 E1200       ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z250 E250          ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30      ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                           ; Set idle timeout
      M574 X1 Y1 S3			  ; set endstops to use motor stall
      M915 X Y S3 R0			  ; set sensitivity to +3 unfiltered
      M208 X0 Y0 Z0 S1                  ; Set axis minima
      M208 X320 Y300 Z290 S0            ; Set axis maxima
      M574 Z1 S0                        ; Set active low endstops
      ;M558 P0 H5 F120 T6000             ; Set Z probe type to switch and the dive height + speeds
      G31 X0 Y0 Z-0.1 P600               ; Set Z probe trigger value, offset and trigger height
      M557 X15:305 Y15:285 S20          ; Define mesh grid
      M558 P1 I0(or I1) R0.4 F300 X0 Y0 Z0   ;Define Z probe as peizo digital
      M307 H0 B0 S1.00                  ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4138 C0 R4700    ; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                      ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 C0 R4700    ; Set thermistor + ADC parameters for heater 1
      M143 H1 S300                      ; Set temperature limit for heater 1 to 300C
      M106 P0 S0.3 I0 F500 H-1          ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is
      turned off
      M106 P1 S0.5 I0 F500 H1 T45       ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is
      turned on
      M106 P2 S0.5 I0 F500 H1 T45       ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is
      turned on
      M563 P0 D0 H1                     ; Define tool 0
      G10 P0 X0 Y0 Z0                   ; Set tool 0 axis offsets
      G10 P0 R0 S0                      ; Set initial tool 0 active and standby temperatures to 0C
        You can increased the probing speed by increasing the F value of the M558 command in config.g
        • ajcraig99
          Thanks,
          I've changed
          To
          M558 P1 I0(or I1) R0.4 F1800 X0 Y0 Z0   ;Define Z probe as peizo digital
          But it doesn't seem to have had any effect on probing speed.
          My homez.g works nicely using the same speed, is it being overwritten from somewhere?
          ; homez.g
          ; called to home the Z axis
          Time)
          G91               ; relative positioning
          G1 Z5 F6000 S2    ; lift Z relative to current position
          G1 S1 Z-295 F1800 ; move Z down until the switch triggers
          G92 Z2.5          ; set Z position to trigger height
          • whosrdaddy
            whosrdaddy last edited by
            @ajcraig99 said in Auto Bed Compensation - Too Slow?:
            I don't understand why people want to define the ppiezo as analog probe
            the correct M558 line would be
            M558 P5 I1 R0.4 F1800 X0 Y0 Z0
            or if you have a recent firmware (1.21 or higher)
            M558 P8 I1 R0.4 F1800 X0 Y0 Z0
              Phaedrux Moderator @ajcraig99 last edited by
              @ajcraig99 Your home Z should be using a G30 probe command instead of a G1 S1 move. That way the probe offset is used to calibrate your z height accurately.
              I assume you've calibrated your z trigger height used in G31?
              ajcraig99 1 Reply Last reply Reply Quote 0
              • ajcraig99
                ajcraig99 @Phaedrux last edited by ajcraig99
                @phaedrux Sorry but im not too sure, most of the settings I got from the firmware builder (https://configurator.reprapfirmware.org/) and didn't save the .json file.
                To get sensorless homing working, I stole alot of the code from this post.
                https://forum.duet3d.com/topic/3585/working-config-for-sensorless-homing-on-a-corexy/10
                I have a Z offset in my config.g , Is this what you mean by calibration?
                When I try to run G30 i get the following error:
                08:44:28   G30 S-2     Error: Z probe already triggered at start of probing move
                Changes made since my last post where as directed by whosrdaddy, my new M558 line is
                ;M558 P1 I0 R0.4 F1800 X0 Y0 Z0   ;Define Z probe as peizo digital - Old
                M558 P8 I0 R0.4 F1800 X0 Y0 Z0    ;Define Z probe as peizo digital - New
                Now if I run G32 it will just move to each of the 5 points without probing, instead just returning that same error.
                I'm so lost man
                  You're getting really close.
                  To get the trigger height you'll need to follow these instructions.
                  https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                  I'm not sure what the ideal settings for the piezoelectric probe are. I think there are a few threads dealing with setting them up specifically. A quick search should get you that.
                  • Ckostikas
                    Ckostikas last edited by
                    Maybe you have to adjust those two z speeds to get it working quicker
                    • ajcraig99
                      @phaedrux Working through that dynamic calibration procedure and I can't get past the G30 S-1 stage,
                      It just crashes into the bed and doesn't trigger the probe.
                      Does my homez.g use the M558 line from config.g? since homez.g works I would expect this line to be correct if it is using it right?
                      if my homez.g doesn't use the M558 line then I guess my issue lies here.
                      I changed I0 to I1 in the M558 line to change to a normally closed switch and now I don't get the error "Error: Z probe already triggered at start of probing move" so at least it tries to probe now.
                      So I currently have
                      M558 P8 I1 R0.4 F1800 X0 Y0 Z0    ;Define Z probe as peizo digital - New
                        Phaedrux Moderator @ajcraig99 last edited by Phaedrux
                        @ajcraig99 when you did the g30 s-1 test did you first change your trigger height in the G31 command to 0 in the config.g?
                        Also try changing the trigger sensitivity to a lower value. That's the P value of the G31 command in config.g. try 100 instead of 600.
                        • ajcraig99
                          @phaedrux
                          Ensure that the Z offset in G1 in config.g is set to 0, these steps will be used to measure this actual offset. (send G31 >Z0 to set it to 0).
                          I though I did but misread that as G31, I have a G31 line where Z=0 (was Z-0.1) but no G1 line in my Config.g
                          Isn't G1 just 'move'? Do I need to add another line in config.g with just
                          G1 Z0
                            Yes I think that's a typo.
                            • ajcraig99
                              Ok, 1 step forward, 1 step backwards.
                              G31 changed to G1 with Z0 but now when I issue G30 S-1 it starts the manual bed probing wizard.
                              M558 is still set to P8 rather than the P0 I would expect to cause this...
                                Nope that should be G31. The g1 is a typo.
                                  I think I would go back through the piezo documentation from the start and follow it to the letter.
                                  Once you get through that if it still doesn't work we can review your config.g and homing files.
                                  • ajcraig99
                                    Typo fixed. Still crashes into the bed.
                                    Have been through the peizo documentation pretty thoroughly over the last week or so. It's not very detailed but I have checked the polarity and got the sensitivity tuned.
                                    It just takes a light tap when running homez.g
                                    https://youtu.be/OKaQNF0DIy0
                                    Snnn Flag to check if an endstop was hit (S1 to check, S0 to ignore, S2+S3 see note, default is S0) 1
                                    Am I right in thinking that the above waits for an endstop to be triggered (which does get triggered in this case) whereas G31 waits for a probe to be triggered ie a different tool or input compared to above?
                                    When I run G31 with the bed 100mm or so away from the nozzle, i can manually trigger the peizo, causing the red light to flash but it ignores it.
                                      So you should not be using G1 S1 Z-295 F1800 in your homez.g. That is only if you are using a mechanical end stop switch. You should be using G30, which tells the system to probe the bed to find z=0.
                                      So lets clear up some terminology because I think it's a little confused right now.
                                      G1 commands are movements. In the command above, the S1 switch tells it to move until an endstop is hit.
                                      G30 tells the system to do a probe. It uses the settings specified in the config.g (G31 and M558) to tell it what kind of probe it is and how it's configured. It then moves the head down until the probe triggers. It takes the trigger height offset and says if I triggered here, the bed is here, and so it knows where z=0 is and can move accurately going forward. G30 is used by your homing files and the various bed leveling options.
                                      G31 belongs in the config.g and defines the physical location of the probe in relation to the nozzle. In your case the nozzle is the probe, so the X and Y values are 0. The Z value tells it what height the nozzle is when it triggers. According to the piezo documentation it should be -0.1 because it actually presses into the bed a little bit.
                                      M558 also in config.g defines the probe type and how it should behave during a G30 command.
                                      So your config.g should have the following lines in it.
                                      M574 Z1 S2						; Use zprobe and home to Z Min.
                                      M558 P8 I1 H5 F300 T6000                 ; Use piezo digital probe type, invert the signal, probe from 5mm height, probe at 300mm/min, travel between probe points at 6000mm/min.
                                      G31 X0 Y0 Z-0.1 P100
                                      M557 X10:280 Y35:270 S15				; Define mesh grid
                                      Then your homeall.g should look something like this.
                                      ; Drop the bed for travel
                                      G1 Z5 F200 S2        		; Lower bed 5mm to ensure it is below the switch trigger height
                                      ; Home XY
                                      G1 S1 X-375 Y305 F4000   	; course home X or Y
                                      G1 S1 X-375 F4000              	; course home X
                                      G1 S1 Y305 F4000              	; course home Y
                                      G1 X5 Y-5 F1000             	; move away from the endstops
                                      G1 S1 X-10 F600           	; fine home X
                                      G1 S1 Y10 F600               	; fine home Y
                                      ; Home Z
                                      G90				; absolute positioning
                                      G1 X190 Y90 F6000		; Move x and Y axis over to bed center so probe is on top of bed
                                      G30 				; Do a single probe to home our Z axis
                                      ; Move X and Y back Home
                                      G1 X1 Y270 Z5
                                      • ajcraig99
                                        Thankyou, I've updated the code and will revisit the peizo setup again.
                                          No problem. You're quite close.
                                          The configurator gives a starting point but there are a lot of pitfalls with the option choices. It can take a bit of manual tuning to get it right.
                                          • ajcraig99
                                            Just reporting back to say I got everything working now. Thankyou very much for the help. The code snippets you posted above are working perfectly.
                                            The issue was entirely user error on my part. I had the probe wired up to the 'Z Stop' on the board instead of 'Z Probe'. A tonne of hassle over a simple mistake but atleast it's sorted now.
                                            Cheers
                                              Glad to hear it's all working now.
