    Temperature sensors in the Extra-tab possible?
    1132
    • Christoph13524
      Christoph13524 last edited by
      Hi!
      Can another temperature sensor be added to the Extra-tab, where the MCU-temperature is shown? When yes, then how?
      Printing with an UMO+
      Duet 2 WiFi 1.04
      wilriker 1 Reply Last reply Reply Quote 0
      • wilriker
        wilriker Moderator @Christoph13524 last edited by
        @christoph13524 The answer here is "it depends". 😉 Can you be a bit more specific on what actually you want to do?
        But this is doable, as I have two DHT22 sensors attached to my Duet and configured so they show up on the Extra tab. You will probably have to define a new/virtual heater with M305 and it is important to give it a name via the S"..." parameter. That is imperative for it to be shown in the Extra tab in the first place.
        Manuel
        My Tool Collection
        Christoph13524 1 Reply Last reply Reply Quote 0
        • Christoph13524
          Christoph13524 @wilriker last edited by
          @wilriker I just want some temperature senors in my heated chamber. Only sensors, no tool or heater. And I don‘t want them to show up in the tool list.
          So just set up one with M305 and the S parameter. And only because of the S parameter it will appear in the extra-tab?
          What is a virtual heater (P parameter)?
          Duet 2 WiFi 1.04
          • wilriker
            wilriker Moderator @Christoph13524 last edited by wilriker
            @christoph13524 said in Temperature sensors in the Extra-tab possible?:
            This is achievable.
            Depending on the type of temperature sensor and how you connect it you do need a virtual heater that will be created by setting the Pnnn parameter as you already guessed. Simply choose any number larger than 102, e.g. 103 in this case.
            If you use a thermistor that is connected to e.g. second extruder thermistor connector on the board you can simply use P2.
            In case you use a virtual heater you will also need to tell it which heater channel it is using by the Xnnn parameter.
            All details about this process can be found at the documentation for M305. If you still have questions don't hesitate to ask here again. In this case please also provide information on what type of temperature sensor and how you want to connect it to your Duet.
            Manuel
            My Tool Collection
            • Christoph13524
              Christoph13524 last edited by Christoph13524
              Now I am home and I could test it.
              I still failed. I was able to list the temperature sensor on the extra-tab but have no clue which channel and heater number it is.
              I have 4 tools with 4 PT100 sensors on the daughterboard which are heater numbers P0, P1, P2, P3 and channels X200, X201, X202, X203.
              Now I connect the thermistor (E3D) to E0. Which heater number it has to be? Something with 100 (hundred for virtual heater --> so it shows up in the extra-tab) --> so P101? (P100 is MCU temperature I think).
              With P101 the thermistor is listed in the extra-tab but it shows 0°C.
              So I need to tell it which channel (X parameter) the temperature sensor is connected to. It is connected to E0. So which channel is E0? X101? --> interferes with X201... --> then X201 and X101 shows 2000°C faults. So why do they interfere? What's the difference between X101 and X201?
              How to connect a thermistor: VSSA is ground and Thermistor 1 is red wire. Correct?
              Duet 2 WiFi 1.04
              • wilriker
                @christoph13524 So, E0's channel number is actually just 0, so that makes X0.
                For the virtual heaters: 100 to 102 are taken up already:
                • 100: MCU
                • 101: TMC over-temperature-warning for drivers on Duet
                • 102: TMC over-temperature-warning for drivers on DueX
                The latter two have just three hard-coded values:
                1. 0°C: everything OK
                2. 100°C: over-temperature warning
                3. 150°C: thermal shutdown
                So you have to take any number starting from 103 to define a new virtual heater.
                That would make a
                M305 S"Chamber temp. top" R4700 T100000 B4750 P103 X0
                About your questions what X101 means:
                Channels 100, 101... are MAX31855 thermocouple channels using chip selects CS1, CS2... on the SPI bus
                EDIT:
                Yes, this is correct.
                Manuel
                My Tool Collection
                  Actually, X0 is the bed thermistor. The E0 thermistor would be X1. So use P103 and X1.
                  • Christoph13524
                    Thanks a lot guys!
                    Everything is working now.
                    Duet 2 WiFi 1.04
                    • wilriker
                      wilriker Moderator @dc42 last edited by
                      @dc42 said in Temperature sensors in the Extra-tab possible?:
                      Thanks for spotting this, that slipped - I should not try to fix message broker settings and reply to complicated forum posts at the same time. 😂
                      Manuel
                      My Tool Collection
                      • Christoph13524
                        Just out of interest, is it possible to list the stepper driver temperature in the extra-tab, too?
                        Duet 2 WiFi 1.04
                        • wilriker
                          @christoph13524 Yes and no.
                          You can easily add the pseudo-heater for temperature warnings to it by adding M305 P101 and assign a name. But that would only give you one of the three generic values as I described earlier.
                          To get the real temperature you'd have to stick thermistors onto the chips and configure them as you did for your chamber sensor.
                          Manuel
                          My Tool Collection
