    Delta Auto Calibration increments
    680
    • reahax
      reahax last edited by reahax
      Hello, im new with duet. I just setup my delta and made calibration with guides. Its working fine but my dimensions need some more calibration. I do not have any probe so im calibrating manually. I cannot fine tuning with 0.1 increments, is there any way to lower to 0.05 or more? My steps are 100 per mm.
      Thanks.
      • Dougal1957
        Dougal1957 last edited by
        this help ?
        • reahax
          I'm talking about this screen not baby step.
          • Dougal1957
            Which Version of DWC Do you have as my default stepping on z is 0.05 which is probably where the manual step takes it from 0_1533024078145_f7e96d1f-1e1d-4eda-8150-af894e071d9e-image.png I am currently on
            • reahax
              my babystepping is also 0.05, definitely not taking from here.
              Firmware Version: 2.0(RTOS) (2018-06-05b3)
              WiFi Server Version: 1.21
              Web Interface Version: 1.21.1
              • Dougal1957
                Dougal1957 last edited by Dougal1957
                that las screen shot was not the baby stepping one it is the machine controller page IIRC in the earlier DWC there was a setting to reduce the Z Steps by Half but that is in the latest one it may be worth upgrading your DWC to either DC42's version or Chrishamms latest beta (there is a recent post from Chris ref this earlier today)
                Chris's DWC Post
                • reahax
                  thanks i will try it when my print is finished.
                  • reahax
                    Ok there is important bug at this web interface. There is no negative below than 5mm.
                      Which DWC version is that?
                      reahax Dougal1957 2 Replies Last reply Reply Quote 0
                      • reahax
                        reahax @dc42 last edited by
                        • Dougal1957
                          Dougal1957 @dc42 last edited by
                          @dc42 it's also mentioned in https://forum.duet3d.com/topic/5485/duet-web-control-wishlist-notes-and-priorities/48
