Duex5 Extruders not working
I have a duex5 attached to a Duet Wifi with firmware 2.00 and cannot get the stepper motors of the extruders to work. Currently the paneldue displays the thermistor readings appropriately for thermistor 1 and 2 of the Duex5, which leads me to believe that the Duex5 is wired correctly. To control the motors I try the following code:
From config:
M569 P5 S1 ; Drive 5 (includes x,y, and z motors) in reverseM305 P3 T100000 B4138 C0 R4700 ; Set heater values (naming does not include x, y, and z motors but does include the bed)
M143 H3 S280 ; Set temperature limit (again excluding x, y, and z but including the bed)M563 P2 D2 H3 ; Define tool 2
G10 P2 X0 Y0 Z0 ; Set tool 2 axis offsets
G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0CM302 P1; Allow cold extrudes
In a terminal:
T2
G1 E20I don't have access to the web interface, but when running these commands from a terminal hooked up through USB I get an "ok" response. I have also verified that I have the stepper pairs wired appropriately and have verified that the stepper works by plugging it into the Duet and following the same code input but for Tool 1. Does anyone have any suggestions on where I might be going wrong? Thank you in advance for your time!
Do you have VIN power connected to the DueX5, via its VIN connector? With just the ribbon cable connected, the thermistors will work but not the heaterts, motors or fans.
@travis-hainsworth It sounds like you haven't mapped the drives to the extruders with M584. It will probably be easier to help if you can post your entire config.g, along with an explanation of which motors are connect to which drives on both the Duet and Duex 5.
Thanks for the replies @dc42 and @deckingman! I have the duex5 powered with 24v from the power supply through the blocks labeled "12v-24v Input" from this overview page. @deckingman you are correct, I have not utilized M584. Why is M584 necessary for using the Duex5 but not necessary for the Duet, and where in config should it go (before M569, before M563, or after M563)? Thanks again for your help!
Here is my entire config.g file:
; generated by RepRapFirmware Configuration Tool on Mon Jul 02 2018 13:33:01 GMT-0600 (Mountain Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 PMy printer ; Set machine name
M540 PDE:AD:BE:EF:CA:FE ; MAC address
;M587 S"UCB Wireless" P"" ; Configure access point. You can delete this line once connected
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S1 ; Drive 0 goes forwards - X
M569 P1 S1 ; Drive 1 goes forwards - Y
M569 P2 S0 ; Drive 2 goes backwards - Z
M569 P3 S1 ; Drive 3 goes forwards E1
M569 P4 S1 ; Drive 4 in reverse - E2
M569 P5 S1 ; Drive 5 in reverse - R2
M569 P6 S1M350 X16 Y16 Z16 E16:16:16:16:16:16:16 ; Configure microstepping with interpolation
M92 X80.35 Y79.84 Z1591 E420:84:420:420:420:420:420 ; Set steps per mm
M566 X900 Y900 Z12 E120:120:120:120:120:120:120 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z180 E1200:1200:1200:1200:1200:1200:1200 ; Set maximum speeds (mm/min)
M201 X1000 Y500 Z500 E250:250:250:250:250:250:250 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800:2000:800:800:800:800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X370 Y250 Z300 S0 ; Set axis maxima; Endstops
M574 X1 S0 ; Set active low endstops
M574 Y1 S0; Z-Probe
M574 Z1 S3 ; Set endstops controlled by probe
M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
G31 P25 X48 Y15 Z1 ; Set Z probe trigger value, offset and trigger height
M557 X15:355 Y15:235 S20 ; Define mesh grid; Heaters
M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
M143 H2 S280 ; Set temperature limit for heater 2 to 280C
M143 H3 S280 ;
M305 P4 T100000 B4138 C0 R4700 ;
M143 H4 S280 ;; Fans
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0 (E1)
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0CM563 P1 D1 H2 ; Define tool 1 (E2)
G10 P1 X-31.5 Y14.2 Z0 ; Set tool 1 axis offsets
G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0CM563 P2 D2 H3 ; Define tool 2 (R2)
G10 P2 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P2 R0 S0 ; Set initial tool 1 active and standby temperatures to 0CM563 P3 D3 H4 ; Define tool 3 (R3)
G10 P3 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P3 R0 S0 ; Set initial tool 1 active and standby temperatures to 0CM302 P1 ; Allows cold extrudes
EDIT: To fully answer your question @deckingman drive 0 controls the x-axis, drive 1 controls the y-axis, drive 2 controls the z-axis, drive 3 controls the first extruder, drive 4 controls the second extruder, and drive 5 is connected to a stepper motor which raises and lowers the second extruder and is the only one connected to the duex5. I have activated multiple drivers on the duex5 and plugged this stepper into them to ensure that the stepper driver on drive 5 is not faulty. Thanks again for your feedback!
Check that the firmware knows that the DueX is present, by sending M115 and looking at the returned electronics description.
The Duex5 is not being recognized. I have:
WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS)
ELECTRONICS: Duet WiFi 1.02 or later
FIRMWARE_DATE: 2018-06-05b3 -
It looks like either the ribbon cable is not connected, or the ribbon cable is faulty, or the DueX is faulty (it's possible but unlikely that the Duet is faulty). If you are sure that the ribbon cable is connected correctly, and you are using the ribbon cable that was supplied with the DueX, please ask your supplier to replace the DueX and the cable.
Thank you @dc42. I will contact duet3d and try to get a replacement.
