    BL Touch issues
    2303
    • Kskiff7034
      Kskiff7034 last edited by
      After accidentally shorting a stepper motor, I got my replacement today and have everything up and running. X and Y axes home just fine.
      I've followed the guide here:
      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_If_you_don_t_have_a_DueX2_or_DueX5_expansion_board
      To set up my BL touch. When I turn my printer on, it does the little test where the probe deploys and retracts twice. The problems start when I run the M280 command -- it does nothing. I've confirmed everything is plugged in correctly and as mentioned, the test works fine.
      I'll post my config.g file below. The ONLY thing I can think of is that maybe I didn't fully cut the logic controller on the BL touch or something -- it's really hard to see so I can't really tell. Would that cause the issues i'm describing? Is there anything I can do to figure out if it's defective?
      M667 S1 ; Select CoreXY mode
      M550 PMy printer ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P4 S1 ; Drive 4 goes forwards
      M584 X0 Y1 Z2:4 E3 ; Apply custom drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z1600 E420:1600 ; Set steps per mm
      M566 X900 Y900 Z12 E120:12 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180 E1200:180 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250:250 ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E800:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X330 Y330 Z400 S0 ; Set axis maxima
      M574 X1 S1 ; Set active high endstops
      M574 Y1 S0 ; Set active low endstops
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F100 T2000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 X-41.8 Y32.2 Z0 P25 ; Set Z probe trigger value, offset and trigger height
      M557 X15:315 Y15:315 S20 ; Define mesh grid
      M140 H-1 ; Disable heated bed
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      • Kskiff7034
        Also, if I manually pull out the pin, the red light goes off. Whether the pin is up or down the Z-probe status reads as 0.
        • Kskiff7034
          One of my other thoughts: maybe since I used the M140 command to disable the heated bed, it's interfering with me using the heater channel?
          • BPisLife
            BPisLife last edited by BPisLife
            Ok, the probe self-testing only means it’s powered properly not wired properly, well not completely anyways.
            Can you take take a picture of your wiring? Also what version of the board do you have?
            Also you disable heater 3 but set the probe to heater 5.
            Your code:
            I need to see where your pwm line is actually connected and then you can set these two commands accordingly.
            Also did you create a deployprobe.g and retractprobe.g?
            • BPisLife
              By the way, I found this guide to be the best. Note the wiring diagram may be off from the board you are actually using so make the connection based on how you have yours wired.
              https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
              Kskiff7034 1 Reply Last reply Reply Quote 0
              • Kskiff7034
                Er, I thought the H in M558 is the dive height?
                "Pnnn Z probe type
                Fnnn Feed rate (i.e. probing speed, mm/min)
                Hnnn Dive height (mm)
                Innn Invert (I1) or do not invert (I0) the Z probe reading (RepRapFirmware 1.16 and later)
                Rnnn Z probe recovery time after triggering, default zero (seconds) (RepRapFirmware 1.17 and later)1
                Tnnn Travel speed to and between probe points (mm/min)
                Annn Maximum number of times to probe each point, default 1 (RepRapFirmware 1.21 and later)
                Snnn Tolerance when probing multiple times, default 0.03 (RepRapFirmware 1.21 and later)
                Bn B1 turns off all heaters during probing moves and during the probe recovery time (RepRapFirmware 1.21 and later)"
                • BPisLife
                  Doh! Right you are. Can you post your deployprobe.g and retractprobe.g files? They need to be in the same spot as the config file
                  Also are you 100% sure the wire is in heater3? Make sure you use the correct wiring diagram as the guides can be outdated.
                  • Kskiff7034
                    Kskiff7034 @BPisLife last edited by
                    @bpislife I actually used that guide first, but when it wasn't working properly I went back to the duet guide and tried that.
                    I'm using the Duet Wifi -- I just bought it new a month ago from Filastruder.
                    deployprobe.g:
                    ; deployprobe.g
                    ; called to deploy a physical Z probe
                    ; generated by RepRapFirmware Configuration Tool on Sun Jul 29 2018 11:50:39 GMT-0400 (Eastern Daylight Time)
                    M280 P3 S10 I1
                    retractprobe.g:
                    ; retractprobe.g
                    ; called to retract a physical Z probe
                    M280 P3 S90 I1
                    BPisLife 1 Reply Last reply Reply Quote 0
                    • BPisLife
                      BPisLife @Kskiff7034 last edited by BPisLife
                      @kskiff7034 Ok, so can you double check that you have yellow plugged into Heater3 (pin 8 ) on the large header? If so, can you send this command in the console: "M280 P3 S10 I1"
                      • Kskiff7034
                        As for wiring, I have it set up exactly as it appears in this picture:
                        https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/KUDxTZSs3rnd3JVH.standard
                        I also tried the other version of setup from the guide that you posted using Heater 7 (Pin 31).
                        • BPisLife
                          @kskiff7034 Ok. Did you cut the 5V line on the back of the bltouch? Also did you send that command manually to the bltouch?
                          • Kskiff7034
                            I did cut the 5v line, but like I said in the original post I can't really tell if it's actually "cut". I used an xacto blade and ran over it quiet a few times, but it's so small you can't really see it. And yes, I sent it manually in the duet browser window in G-Code Console. I've also tried using a macro.
                            • BPisLife
                              BPisLife @BPisLife last edited by
                              This post is deleted!
                              • Kskiff7034
                                I have a multimeter but I'm not very experience with it. I've used it a handful of times to test different things but wasnt sure how to do so on the BL touch.
                                • BPisLife
                                  @kskiff7034 Take a resistance measurement across the two exposed pads (on either side of your cut). The resistance should be large.
                                  • Kskiff7034
                                    This'll take awhile. Getting the BL touch off is kind of a pain. Will report back in a bit.
                                    • BPisLife
                                      @kskiff7034 Ok. It can be frustrating at first. It took me several hours the first time to figure out everything I was doing wrong. I have 4 of them working on my various printers. While its apart triple check your connection, your crimps, etc.
                                      • Kskiff7034
                                        @bpislife So with the multimeter set to 200, touching the 2 pads causes the numbers to jump around wildly before settling on .4 for a few seconds and then dropping to .3
                                        • Kskiff7034
                                          Setting it to 2000, 20k, 200k, and 20m cause it to jump around wildly before settling at 0, but setting it to 200m it settles at .9? So confused.
                                          • Kskiff7034
                                            Ok so I'm having doubts about whether I cut the pcb trace correctly.
                                            Looking at this image:
                                            https://static.wixstatic.com/media/f5a1c8_11bd24d2d4974b2998c8d2a6736df1b3~mv2.png/v1/fill/w_637,h_308,al_c,lg_1/f5a1c8_11bd24d2d4974b2998c8d2a6736df1b3~mv2.png
                                            Am I supposed to cut the little line between the two pads, or one of the lines near 5 or 6? I thought it was the line between the two pads, but now I'm not sure.
                                            • Qdeathstar
                                              Qdeathstar last edited by
                                              between the two pads.
                                              • Kskiff7034
                                                Hm okay that's what I attempted to do, but maybe I didn't succeed? I don't want to keep sawing away at it though. Sigh.
                                                • Qdeathstar
                                                  can you take a picture of your wiring. I think you have it wired wrong. I just set one of these up last weekend and it was a breeze.
                                                  How are the lights blinking on the bl touch.....
                                                  • Qdeathstar
                                                    Do you know how to use a multimeter?
                                                    .4 doesn’t tell me anything.. .4ohms is very low. At 200ohms, i would expect it to read OL
                                                    • Qdeathstar
                                                      You need to turn th multimeter to the thing that sorta looks like a horseshoe.
