Arduino to compile and update the code
how can i update the reprap firmware to the duet 0.8.5 kit through arduino ide
and whats is the library that i will need it
and how i can compile the all code in arduino and change in it and update it to the kit
Hi. There is no requirement to compile the firmware. Changes to reflect your machine are.made in config.g
Please start by reading the Wiki documentation:
https://duet3d.com/wiki/Duet_Wifi_Wiki#If_you_are_not_familiar_with_Duet_electronics_or_RepRapFirmware
i know what dii you mean but i mean i want to update the code through arduino not through bossac and the command window
i want to know how to open the firmware in the arduino and compile it and update it correctly
that is correctly i mean
There is build instructions on github
https://github.com/dc42/RepRapFirmware/blob/dev/BuildInstructions.txt
But it uses Eclipse to compile
