    DC42 Precision Kossel
    Example setups and prints
    • srmatthe
      srmatthe last edited by
      One for @dc42
      I've recently built a large Kossel based off your Precision Kossel BoM and was wondering whether you'd be able to share the duet config that you've used on it?
      The blog post ends with a TBC at the point where you go into commissioning the Duet.
      I have had a mess with setting up the Duet 0.8.5 in the past on a Cherry Pi 4XL build and figured with this one I could cut out most of the head scratching this time with a base set of files. I know i'll still need to modify some of the values so no problem there.
      Thanks in advance
        Sure, it's at https://www.dropbox.com/s/golwo91wdmucpaz/KosselConfig.zip?dl=0. There may be a few odd things in config.g because of firmware features I was testing.
        • srmatthe
          Cheers, much appreciated.
