    P Peizo and really basic newb question
    • 3dmntbighkerundefined
      3dmntbighker
      Is it generally best practice to have the printer / firmware / bed level compensation set the nozzle at zero clearance, and have the slicer handle the first layer nozzle clearance? Or do you want the firmware to start the job with the set clearance?
      Scratch built CoreXY with Maestro
      Heavily modified Ender 3 with Maestro
      MPCNC work in progress with Duet WiFi
        dc42 administrators @3dmntbighker
        @3dmntbighker said in P Peizo and really basic newb question:
        If you set the Z height so that Z=0 is when the nozzle is just touching the bed, then it should just work. Some slicers have an option to adjust the extrusion rate for the first layer, which may be helpful if your bed surface and filament benefit from a little deliberate over-extrusion.
