    Error Status 16
    • boldnuts
      boldnuts last edited by
      Just wondering about this error, but as my printer is working well it can't be much?
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-956GU-DJMSJ-6JKF2-3S86K-TBPRG
      Used output buffers: 1 of 20 (15 max)
      Static ram: 28476
      Dynamic ram: 95896 of which 0 recycled
      Exception stack ram used: 420
      Never used ram: 6280
      Tasks: NETWORK(ready,328) HEAT(blocked,1248) MAIN(running,3476)
      Owned mutexes:
      Last reset 00:27:54 ago, cause: software
      Last software reset at 2018-08-10 15:39, reason: User, spinning module GCodes, available RAM 6280 bytes (slot 3)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 16
      Free file entries: 10
      SD card longest block write time: 389.1ms, max retries 0
      MCU temperature: min 30.4, current 30.6, max 33.1
      Supply voltage: min 12.1, current 12.4, max 12.4, under voltage events: 0, over voltage events: 0
      Driver 0: standstill, SG min/max 692/1023
      Driver 1: standstill, SG min/max 618/1023
      Driver 3: standstill, SG min/max 0/1023
      Date/time: 2018-08-12 15:55:39
      Slowest loop: 102.85ms; fastest: 0.07ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 137, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: mesh
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.7
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 389.71ms; fastest: 0.02ms
      HTTP sessions: 2 of 8
      Interface state: 5
      === Expansion ===
      • T3P3Tony
        T3P3Tony administrators @boldnuts last edited by
        @boldnuts said in Error Status 16:
        Error status
        see this documentation page:
        https://duet3d.dozuki.com/Wiki/Error_codes_and_software_reset_codes
        so as a bitmap however what 0x16 refers is not documented so hopefully @dc42 can add what it means
        Duet Hardware Designer
        www.duet3d.com
          I have just updated that wiki page. Error code 16 means that an SD card operation timed out waiting for an interrupt after 200ms.
          • boldnuts
            Thank you David
