    Stepper Motor Driver dm542t With Duet 2 Wifi
    Third-party add-ons
    • yamanundefined
      yaman
      Hi every one
      I'm looking for 3D Printer Controller and I like Duet 2 Wifi it's will make my life easier than the SD card controller
      My question is can I connect stepper motor Nema 23(425oz.in) with driver DM542T with this controller and how I can Disable the built in Driver
        You can connect up to 7 stepper drivers to the expansion connectors of the Duet. The outputs are 3.3V with limited current capacity, so we recommend you use this https://www.duet3d.com/DuetAddons/Expansion_Breakout to boost the signals to 5 external large stepper drivers.
        You can use the M584 command in the boot-time configuration file to remap axes to your external drivers, and reallocate the spare internal drivers as additional extruders if you wish.
