    Duex5 shown as Duex2
    • miguel
      miguel last edited by
      Hi, I am trying to wire a Duex5 but it shows as Duex2 in the M115 command when connected over USB.
      Is there any configuration to change the board type? or is this a bug?
      • T3P3Tony
        T3P3Tony administrators @miguel last edited by
        @miguel it is automatically detected based on some resistors on the port expander on the Duex5. can you send a picture of the board, especially around this area:
        Duet Hardware Designer
        www.duet3d.com
        • miguel
          miguel last edited by miguel
          @T3P3Tony This is what I am able to capture right now. Let me know if you need different or better quality images.
          • T3P3Tony
            @miguel that looks correct - the board ID resistor is populated which should indicate Duex5.
            Can you paste the M122 report.
            www.duet3d.com
            • miguel
              @T3P3Tony
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet Ethernet 1.02 or later + DueX2
              Board ID: 08DGM-956GU-DJMSN-6J9D6-3S46L-9VQRH
              Used output buffers: 1 of 20 (12 max)
              Static ram: 28476
              Dynamic ram: 95552 of which 0 recycled
              Exception stack ram used: 276
              Never used ram: 6768
              Tasks: NETWORK(ready,464) HEAT(blocked,1248) MAIN(running,4324)
              Owned mutexes:
              Last reset 00:00:24 ago, cause: reset button or watchdog
              Last software reset at 2018-08-22 16:05, reason: Heat task stuck, spinning module Platform, available RAM 6376 bytes (slot 3)
              Software reset code 0x40a0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20005344 Task 0x4e49414d
              Stack: 00403181 00441a40 81000000 460ca000 3ff00000 00000000 00000000 3e178897 3e1cd04f 41880000 3e3a3fd4 3e639b49 3e9250f0 3c942078 3eccd653 be09b238 397d66d2 80000000 00007530 20000010 0043a809 00000000 004393ef
              Error status: 0
              Free file entries: 10
              MCU temperature: min 34.2, current 36.9, max 37.1
              Supply voltage: min 24.4, current 24.5, max 24.5, under voltage events: 0, over voltage events: 0
              Driver 5: standstill, SG min/max not available
              Driver 6: standstill, SG min/max not available
              Expansion motor(s) stall indication: no
              Date/time: 2018-08-22 16:14:58
              Slowest loop: 4.25ms; fastest: 0.07ms
              Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
              Scheduled moves: 0, completed moves: 0
              Bed compensation in use: none
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 5.09ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
              Interface state: 5
              === Expansion ===
              DueX I2C errors 0
              Sometimes I manage to get the board correctly identified by power cycling or resetting the board. Here is a M122 with the Duex5 correctly identified:
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet Ethernet 1.02 or later + DueX5
              Used output buffers: 3 of 20 (17 max)
              Static ram: 28476
              Dynamic ram: 95660 of which 0 recycled
              Exception stack ram used: 356
              Never used ram: 6580
              Tasks: NETWORK(ready,328) HEAT(blocked,1248) MAIN(running,3912)
              Owned mutexes:
              Last reset 00:04:10 ago, cause: reset button or watchdog
              Error status: 0
              MCU temperature: min 35.7, current 37.5, max 37.6
              Supply voltage: min 24.4, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0
              Driver 0: standstill, SG min/max 0/227
              Driver 1: standstill, SG min/max 0/205
              Driver 2: standstill, SG min/max 0/1023
              Driver 7: standstill, SG min/max not available
              Driver 8: standstill, SG min/max not available
              Driver 9: standstill, SG min/max not available
              Date/time: 2018-08-22 16:13:05
              Slowest loop: 3.40ms; fastest: 0.08ms
              Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 239, MaxWait: 238706ms, Underruns: 0, 0
              Scheduled moves: 8, completed moves: 8
              Segments left: 0
              Stack records: 4 allocated, 0 in use
              === Network ===
              Slowest loop: 5.22ms; fastest: 0.03ms
              Interface state: 5
              === Expansion ===
              DueX I2C errors 0
              • T3P3Tony
                @miguel i would like to confirm with @dc42, but I note there are no i2c errors which implies the communication between the Duet and the Duex is working OK (so the grounding and ribbon cable is good). It may be an intermittent error with U8 on the Duex5.
                www.duet3d.com
                  I agree, intermittent issue with U8 is the most likely cause. Please ask for your DueX5 to be replaced under warranty. https://www.duet3d.com/warranty
