    M208 and Deltas
    • fcwiltundefined
      fcwilt
      I have read the the M208 command does not apply to deltas BUT I see a M208 S1 Z0 in my config file.
      Does that make any sense?
      Thanks.
      • T3P3Tonyundefined
        T3P3Tony administrators @fcwilt
        @fcwilt have a look here:
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Measuring_the_trigger_height
        That line is limiting your movement in Z to Z = 0 (which is generally a good idea, you don't want to be able to command your printed to bury the head in the bed!
        www.duet3d.com
        • fcwiltundefined
          fcwilt
          Thanks much.
          I will have to read the referenced material more closely as a quick scan didn't reveal if that command is essential for normal operation or not.
            The M208 minimum Z value does apply to deltas. The M208 XY min/max and Z max values don't.
            fcwiltundefined 1 Reply Last reply Reply Quote 1
            • fcwiltundefined
              fcwilt @dc42
              @dc42 said in M208 and Deltas:
              The M208 minimum Z value does apply to deltas. The M208 XY mind/max and Z max values don't.
              Thank you.
              That is just what I needed to know.
              Perhaps a note should be added to the G-codes documentation explaining this.
              • T3P3Tonyundefined
                @fcwilt said in M208 and Deltas:
                I have added it, thanks.
                www.duet3d.com
                • fcwiltundefined
                  fcwilt @T3P3Tony
                  @t3p3tony said in M208 and Deltas:
                  That's great - perhaps other confused folks like me will find it helpful.
