    Part Cooling Fan
    • GBusy24
      GBusy24 last edited by
      My part cooling fan has stopped working. There seems to be a failure associated with the PWM Fan0 port that I have that fan connected to. It shows 24.1 volts w/ no load, but w/ the fan attached, voltage drops to 2.6. I attached another fan that I know to be good to it and have the same result. Advise please.
      No such thing as spare time. No such thing as free time No such thing as down time. All you got is lifetime. Go!
        Sounds like a bad connection or a failed MOSFET - although that's a strange failure mode for a MOSFET.
        When you set the fan to fully on with a fan connected, is it the positive terminal that isn't at +24V, or the negative terminal that isn't at 0V?
        • GBusy24
          Negative terminal is showing 21.3.
            In that case, my guess is that the Fan0 mosfet has failed.
            • GBusy24
              Any type of warranty with these boards?
                Yes, speak to your supplier.
