Always misaligned after 3 point probing (3 stepper)
  • Hi! -
    So im building a D-bot with a custom Z-axis -
    The Z axis uses 3 independent steppers and the DC42 IR probe. - But after running the G32, the X-axis is alway tilted a bit -
    ![Bed picture](0_1535554029844_7903e293-9160-472e-90b4-a927fc226649-image.png image url)
    What can cause this?
    My config file looks like:
    M586 P0 S1                                                             ; Enable HTTP
    M586 P1 S0                                                             ; Disable FTP
    M586 P2 S0                                                             ; Disable Telnet
    M569 P0 S1                                                             ; Drive 0 goes forwards
    M569 P1 S0                                                             ; Drive 1 goes backwards
    M569 P2 S1                                                             ; Drive 2 goes forwards
    M569 P3 S1                                                             ; Drive 3 goes forwards
    M569 P4 S1 C65972                                                           ; Drive 4 goes forwards
    M569 P5 S1                                                             ; Drive 5 goes forwards
    M569 P6 S1                                                             ; Drive 6 goes forwards
    M569 P7 S1                                                             ; Drive 7 goes forwards
    M569 P8 S1                                                             ; Drive 8 goes forwards
    M569 P9 S1 C65972                                               ; Drive 9 goes forwards
    M584 X4 Y9 Z0:1:2 E6:7                                                     ; Apply custom drive mapping
    M350 X16 Y16 Z16 E16:16 I1 S2                                            ; Configure microstepping with interpolation
    M92 X200 Y200 Z800 E415:415                                           ; Set steps per mm
    M566 X1500 Y1500 Z18 E300:300                                          ; Set maximum instantaneous speed changes (mm/min)
    M203 X8400 Y8400 Z800 E2400:2400                                       ; Set maximum speeds (mm/min)
    M201 X500 Y300 Z250 E250:250                                           ; Set accelerations (mm/s^2)
    M906 X1200 Y1200 Z1000 E1500:1500 I40                                  ; Set motor currents (mA) and motor idle factor in percent
    M84 S10                                                               ; Set idle timeout
    M208 X0 Y0 Z0 S1                                                       ; Set axis minima
    M208 X320 Y290 Z500 S0                                                 ; Set axis maxima
    ; Define the X and Y coordinates of the leadscrews.
    ; Must come after M584 (Set drive mapping), M667 (Select CoreXY Mode) and M669 (Choosing Kinematics type)
    ; Motor order: Front right (1), front left (2), rear center (3).
    ; Snn Maximum correction in mm to apply to each leadscrew (optional, default 1.0)
    M671 X-50:385.0:385.0 Y170:35:310 S20 P2
    M574 X1 Y1 S3                                                          ; Set endstops controlled by motor load detection
    M574 Z1 S2                                                             ; Set endstops controlled by probe
    M558 P1 H5 F620 T6000                                                  ; Set Z probe type to modulated and the dive height + speeds
    G31 P500 X0 Y47 Z3                                                     ; Set Z probe trigger value, offset and trigger height
    M557 X20:320 Y50:280 S20                                               ; Define mesh grid
    M305 P0 T100 B4202 C4.387169e-7 R4700                                  ; Set thermistor + ADC parameters for heater 0
    M143 H0 S80                                                            ; Set temperature limit for heater 0 to 80C
    M305 P1 T100000 B4725 C7.060000e-8 R4700                               ; Set thermistor + ADC parameters for heater 1
    M143 H1 S360                                                           ; Set temperature limit for heater 1 to 360C
    M305 P2 T100000 B4725 C7.060000e-8 R4700                               ; Set thermistor + ADC parameters for heater 2
    M143 H2 S360                                                           ; Set temperature limit for heater 2 to 360C
    M106 P0 S0.3 I0 F500 H-1                                               ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1:2 T45                                            ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H1:2 T45                                            ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1                                                          ; Define tool 0
    G10 P0 X0 Y0 Z0                                                        ; Set tool 0 axis offsets
    G10 P0 R0 S0
                                                            ; Set initial tool 0 active and standby temperatures to 0C
    M563 P1 D1 H                                                           ; Define tool 1
    G10 P1 X18 Y0 Z0                                                       ; Set tool 1 axis offsets
    G10 P1 R0 S0                                                           ; Set initial tool 1 active and standby temperatures to 0C
    M501        ; Load saved parameters from non-volatile memory
    Home all
    ; homeall.g
    ; called to home all axes
    ; generated by RepRapFirmware Configuration Tool on Tue Jul 31 2018 15:05:50 GMT+0200 (Centraleuropæisk sommertid)
    M400; make sure everything has stopped before we make changes
    M574 X1 Y1 S3		;
    M913 X30 Y30 		; XY motors to 30% current
    M915 X Y H400 S3 R0 F0	; set X and Y to sensitivity , do nothing when stall, unfiltered
    ; X axis home
    G91			; use relative positioning
    G1 Z5 F6000 S2    ; lift Z relative to current position
    G1 S1 X-405 F6000 ; move quickly to X axis endstop and stop there (first pass)
    G1 X5 F6000       ; go back a few mm
    G1 S1 X-405 F4000  ; move slowly to X axis endstop once more (second pass)
    ; Y axis home
    G1 S1 Y-305 F6000 ; move quickly to Y axis endstop and stop there (first pass)
    G1 Y5 F6000       ; go back a few mm
    G1 S1 Y-305 F4000  ; move slowly to Y axis endstop once more (second pass)
    G90               ; absolute positioning
    M913 X100 Y100; motor currents back to 100%
    ; Z-axis
    M561                     ; Clear any bed transform
    G32                      ; Start 3-point probe sequence - Bed.g
    G1 Z20.0 F6000           ; Move Z to 20
    G1 X5 Y5    		 ; Move Head to front left
    and my bed.g:
    ; bed.g
    M117 g28;
    G28 Z;
    G29 S2; Clear bed height map
    ; Probe the bed at 3 points
    G30 P0 X0 Y160 Z-9999 ; Front Right
    G30 P1 X320 Y47 Z-9999 ; Front Left
    G30 P2 X320 Y280 Z-9999 S3 ; Center Rear
    It is always the same error where the right side (x+) is lower than the left side (x-)
  • First guess is that the order of your steppers on the board doesn't match the order you have them configured.
    That order for the Z steppers needs to match the order here:
    If not, the corrections applied will be to the wrong leadscrew.
  • that helped a bit
    Still a bit much noise it looks like - The bed should be pretty flat - It is an 6mm cast aluminium (similar to MIC6 ) and have a printsheet on top (chinese magnetic buildtak)
  • Moderator
    Is the buildtak sheet reflective?
    I suggest setting a sheet of paper on top of the bed and trying again.
    Yes, it looks like the IR sensor doesn't work well with that bed surface. What does the surface look like?
  • @dc42
    Right now it is a little bit blank - it is the magnetic part of one of those aliexpress magnetic print surface - Will try with the print surface on when i get back (the Matt print surface you print on the magnetic sheet)
