    Adapter to connect Duex4 to the DuetWifi ?
    Hardware wishlist
    1.2k
    • Pumluxundefined
      Pumlux
      I think there is no similar thread open yet.
      Somewhere was mentioned that the Duex4 is not compatible to the DuetWifi.
      Is this just due to different pinout and size on the expansion header ?
      In this case a dump adapter would be alow reuse of the Duex4, a benefit for people having it already today and also it means you can sell the Duex4 also for the DuetWifi.
      A special ribon cable may do it, or an adapter board from 50-pin to 40-pin.
      Just some thoughts, as I have one Duex4 in my drawer already 🙂
      Regards
      Pumlux
      Using a own build of a Mendel Max , Duet Wifi, Bed 8 mm Aluminium PEI 500 x 280 x 400 230 V 850 W, original E3D Chimera hotend with bowden length 700 mm, since short time with a BL-Touch, Steppers : mostly Nema 17 and one Nema 23 for Y-axis
        Yes, it would be possible and basically just a matter of allowing for the different pin assignments. However, the Duet WiFi build of RepRapFirmware does not include support for the digipots used on the DuetX4 to set the motor currents, although you could add that back in. Also missing in the firmware at present is a way of deciding whether drivers beyond the first 5 are TMC2660s, or dumb step/dir/enable drivers - but I will be adding that at some point.
        • Pumluxundefined
          Pumlux
          It sounds great that a reuse of the Duex4 is theoretical possible and planned.
          As the DuetWifi has on the expansion header signals for an 5 'th stepper, would it than be possible to use the 5'th expansion channel for a complete different stepper driver ?
          I'm looking for some powerful driver of 5A which requires Enable, Direction and Step.
          Current settings are made with jumper on the driver board, so no support from firmware is required there.
          • T3P3Tonyundefined
            T3P3Tony administrators
            Hi Pumlux
            The pin outs on the header are different enough that it would either be a really complicated cable, individual pin-pin cables (no recommended for long term use) or a PCB to provide the pin-pin routing.
            Currently planned for production is a Duex5 which will have up to 5 channels of TMC2660s populated and a "dumb" interface board for external drivers, see the discussion here:
            https://www.duet3d.com/forum/thread.php?id=3
            When I design he "dumb" interface board I might be able to add a header for duex4, depending on space and demand.
            www.duet3d.com
