SOLVED I suspect I may have damaged my PanelDue 7i
I was using my Duet Wifi and I bumped the erase button on my panel Due. The screen froze. I tried pressing the reset button on the PanelDue which did not have any effect. I powered off the Duet board waited a bit and turned it back on. At that point I only got the blank illuminated white screen (image attached). I connected to the board via Wifi and can confirm the Duet is working fine, just not the PanelDue 7i. Any ideas what might have happened? -
You need to reflash the firmware of the PanelDue, you've erased it
Many thanks!
