Past Print Times
How can I tell how long a print took after it finished?
The timer tell me how long a print has been going on, but unless I watch it at the very end, Print Duration clears itself after the print has completed. Is there a command I can use to tell this?
Also, does the Duet2 keep track on how much print time/length it has accumulated since it was first turned on?Thanks!
Check the gcode console. There is a message at the end of the print saying how long it took. It would be nice if that time could get saved to the gcode file as well.
I checked the console but obviously missed it. I will check again after my current print.
Thanks!
@phaedrux said in Past Print Times:
It is! But chirhamm hasn't updated DWC to display it yet. PanelDue displays the most recent actual or simulated print time.
Is there any way to have this sort of information saved to a text file at the end of every print?
If you enable logging then the print completed message with the print time in it will be Included in the log file.
Thanks for the tip! Just what I wanted!
