    X and Y moving on Homez after centering Maestro?
    • cabal2000
      cabal2000 last edited by
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool on Wed Sep 19 2018 19:43:59 GMT-0230 (Newfoundland Daylight Time)
      G91 ; relative positioning
      G90 ; absolute positioning
      G1 X30 Y30 F6000 ; go to first probe point
      ;G91 ; relative positioning
      ;G1 S2 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      As you can see this is stock Homez.g from RRF Configuration Tool. I am using a Orion Piezo with no luck so far BUT when the Z-bed is moving up the X and Y are also moving slowly to the back and to the left. The only other mod to the firmware is to the Config.g under Z-probe.
      M558 P8 I1 H2 R0.5 F300 T6000 ; Set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X30:265 Y30:265 S20 ; Define mesh grid
      cabal2000 1 Reply Last reply Reply Quote 0
      • cabal2000
        cabal2000 @cabal2000 last edited by
        @cabal2000
        OK. I just tried I new install of the configurator but without but No z-stop and that worked, strange!! If I select Switch the x,y moves on Homez!!
          Do you have axis skew compensation enabled, with a M556 command in config.g?
          • cabal2000
            cabal2000 @dc42 last edited by
            I double checked the config file and also the Configurator page ( i have to keep it up because I am getting a Finish error if I try to save from uploaded json file) and its not enabled. Unless it is loaded on default when you select "switch" in z-probe. FYI, I did update to 2.02 last night with same results.
