Fan connectors dont work anymore
my fan connectors dont work anymore. i had a couple of weeks ago a short on my fan, since that time i have my fan and layer fan on my psu. but now i want to fix this problem.
is there a fuse somewhere? of should i look on something.
i get about 1 volt on my always on fan connector.and how do you call the connectors on the board. (the white ones) it is jst? i broke some, so i want to change that.
@dc42 wow thanks i dont know that page.
i order the partsmany thanks
@mickey30m, the connector part numbers on that page are for the shells and crimps that fit on the cables, but if you look up those part numbers you will find the part numbers for the connectors that you want to replace on the board.
If your Duet is a version 1.03 or 1.04 then the reason the fans don't work is most likely that the 1A blade fuse has blown.
@dc42 i have a 1.04
okay thanks i ordered some so i hope there will be soon delivered.
maybe time for another duet. for my other printer -
No that's not the right mosfet. Search for PMV40UN2.
someone tell me if the mosfet is done??
;-)_ -
Sometimes when the mosfets fail there is a hole or burn mark in them, but those look OK.
Do the always-on fan connectors work? If not, then the blade fuse has probably blown.
@dc42 blade fuse is the blue (car fuse) ?
I now have disconnected everything so i will check IT and put power on it to test
Question when i disconnected everything and power the board. And in web control i slide the fan on. It will put power on the fan connector?
