    Heating error sometimes. (Solved)
    521
    • roth
      roth last edited by roth
      i have a Problem with my tevo little Monster.
      If I start printing and set the heating bed temperature to 115 degrees, the error occurs.
      If the heating bed has warmed up a bit before, it won't come any more.
      A similar behavior with the print head.
      Since eigendlich the hot bed over a Relai is steered it might not be at a too high current.
      Or is there a temperature limit somewhere ?
      Because I also see that when heating up always something about the set temperaur is heated up first.
        Have you run heater turning on the bed heater?
        • roth
          roth last edited by
          I'm not quite sure if I did both or just the print file. I mean, it is. But I can do it again.
          • roth
            roth last edited by
            I can tell you more in a few minutes. Heating up right now.
            • roth
              roth last edited by
              No, it's not working.
              It heats up and exactly when it reaches the set 120 degrees comes the error message.
              • roth
                roth last edited by
                Is there a more accurate error log somewhere ?
                The whole thing fits mostly at higher temperatures at 60 degrees less often.
                • boldnuts
                  boldnuts last edited by boldnuts
                  Have you set max temp up? up
                  M305 P0 T100000 B4607 C8.950070e-8 R4700 ; BED : Set thermistor + ADC parameters for heater 0
                  M143 H0 S130 ; Set temperature limit for heater 0 to 130C - BED HEATER
                  roth 1 Reply Last reply Reply Quote 1
                  • roth
                    roth @boldnuts last edited by
                    @boldnuts Oh it stands by 120 C. I will try it with 130C
                    • roth
                      roth last edited by
                      Thanks works fine.
                      I need to see what temperature I'm setting this to.
                      I think Tevo does not give any official value. For a TLM.
                      I do not know the exact maximum value. In many descriptions it says 120 degrees.
                      What surprises me however at the attitude that he may not reach the maximum value. Because somehow one must adjust that yes.
