    Offset for dc42 IR sensor
    • jnofsinger
      jnofsinger last edited by
      I have recently moved my IR sensor to the front of a delta, below the fan. This required a new Y offset, I noticed there is a G31 command in config.g and one in bed.g. What are the differences, if any? Originally the bed.g wasn't set which caused the sensor to go off the bed. Currently it is only set in bed.g and works with the auto-calibrate fine.
      Thanks,
      Jim
        You only need to set the offset once, in config.g. Setting the offset in bed.g on a delta is a hangover from when it was necessary to set zero offset when doing delta calibration.
        • jnofsinger
          Thanks for the clarification!
