    Simplify3D settings
    3.6k
    • a96bimmerm3gmail.comundefined
      Just wanted to see if any of you were using Simplify3D with your duet/duet wifi. Wanted to know if there's any specific settings I should keep in mind.
      I had repetier on my RAMPS board and repetier refused to accept my retraction settings- was pretty difficult to get the prints correct. Figured I'd ask before jumping in.
      Thanks!
      • kylesmthundefined
        kylesmth
        I'm using simplify 3d but only as a slicer not a controller. What kind of hot end / extruder set up are you running? That will make a big difference for settings.
          E3D v6 heatbrake with volcano with a 0.8mm nozle now- I had a regular 0.4 clone before (The volcano has been awesome!). Definitely not intending to use it as a controller, just not sure of the work flow with my Duet board.
          • InSanityundefined
            InSanity
            I'm using S3D as well, the only setting I made sure of was to check Relative extrusion distances under the G-code tab. If you use the setup wizard in S3D for a reprap/marlin printer you should be good. I have Marlin emulation set in my config.g as well.
            M555 P2 ; Set output to look like Marlin
            Jeff
            Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
              Thanks Jeff!
