    BL Touch what to do next
    • nickt
      nickt last edited by
      Help please what to do next ????
      BL Touch installed and seems to be working
      Run : M280 P3 S10 I1 ---- probe extends
      Run : M280 P3 S120 I1 ---- Probe extends , retracts , extends etc etc on about once a second . If I then touch the probe it stops and flashes red .
      Run : M280 P3 S160 I1 ----- Then ran the M code to allow me to lower the Z axis as I have not set up a home for the Z acts yet ( use the Z probe )
      I ended up with a Z axis number of -39.30 . the instructions then say to use that as the Z number in the G32 in the config file .
      surly that number is relative to where i start the the Z moment down from ??
      How do I progress on to using the bl touch as my Z stop , to say nothing to how to get it making up a bed mesh file
      This is the Z probe part from the config
      Z-Probe
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
      M557 X15:375 Y15:375 S20 ; Define mesh grid
      any help gratefully received I think I am close to finally getting to print a test cube 🙂
      • BLV
        BLV last edited by
        i think this guide can help you adjust your Z height with the bltouch:
        https://betrue3d.dk/bltouch-on-duet-wifi-duetreprapfirmware/
        • BLV
          BLV last edited by
          and then this one:
          https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
          • nickt
            Thanks,
            I have worked through this and have hit one problem.
            When I home the z axis the x axis goes across to the side and then slowly lowers the Z but as you can see in the picture the probe is off the bed .
            I have tried the X compensation Both in positive and negative plus increasing the amount Currently at -41 actual amount is more like -27 and I have amended M557 to x35 and y35 to bring the probe in . In all cases the probe does not alter its off the bed position.
            G31 P25 X-41 Y-27 Z3.29 ; Set Z probe trigger value, offset and trigger height
            M557 X35:375 Y35:375 S40 ; Define mesh grid
            • nickt
              and how do you add pictures pls
                Give these a read if you haven't already
                https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
                https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                https://duet3d.dozuki.com/Wiki/Setting_up_automatic_probing_of_the_print_bed
